08-13-2014, 18:53 | #1 (permalink) |
Major Poster Join Date: Aug 2009 Location: United Kingdom
Member: 1101362 Status: Offline Thanks Meter: 1 | is antenna in rear case ? I recently broke my 5 screen so thought i would change the rear case at the same time as the screen , It went well apart from breaking the power button with my tweezers . I used it with the broken screen till the new button flex arrived but noticed although i had full signal when i was in good coverage area , when in a bad area (at work ) i got no service where as before i would get one sometimes 2 bars . I replaced the button flex and screen in the hope my signal would improve but still get the same , no service at work . When i move to an area which i know has good signal i still have no service until i try and use it or switch airplane mode on and off again .. Is the antenna for the 5 built into the rear case ? , i am tempted to change the rear case back to my old one to see if i get my good signal back . I have tried the reset network settings and also a hard reset . |
08-21-2014, 20:38 | #2 (permalink) |
Member: 1101362 Status: Offline Thanks Meter: 1 | OK . so took everything out again and made doubly sure i hadnt missed anything , still the same no service in low signal strength area . So last night i changed the rear case back to my original battered one . Sucess !! at work today i had 2 bars of signal all day and even got 3g outside ! so if anything its slightly better than it was originally ,, so the replacement rear case WAS screwing my signal up !!!! strange. |
