Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-28-2015, 09:28   #1 (permalink)
Member: 1512942
Thanks Meter: 26
Apple Iphone 6 Display blank
i have an iphone 6
display stay blank
after restoring no error but same issue
tried changing the lcd also
display remains blank
Old 12-28-2015, 13:15   #2 (permalink)
Member: 225492
Thanks Meter: 54
check the back of lcd if you have light then can be backlight fuse.
Old 12-29-2015, 02:59   #3 (permalink)
Member: 2416806
Thanks Meter: 9
This.
Or it could also be the screen? Have you tested another screen?
Old 02-05-2016, 09:44   #4 (permalink)
Member: 448942
i have the same problem....i have change with new lcd and the problem stil same ...after turn on the iphone the lcd come apple logo n then blank
hellp...nead solution
Old 02-05-2016, 11:31   #5 (permalink)
Member: 1512942
Thanks Meter: 26
try to flash ios 9.3 or latest 9.2.1
i was able to solve iphone 5s dfu error by flashing 9.2.1
Old 02-06-2016, 12:05   #6 (permalink)
Member: 448942
i chek the conector j2019 number 14 no have resistan AP_TO_LCM_RESET_CONN_L
the line go to u0201 in e4
thank's before
Old 02-06-2016, 12:15   #7 (permalink)
Member: 1298516
Thanks Meter: 14
Check for longer screw caused damage near to the lcd. Same like with the iphone 5s error 9, error 14
Old 02-06-2016, 12:36   #8 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
Will not be solved by software, after water damage.
Old 02-06-2016, 13:19   #9 (permalink)
Crazy Poster
Member: 1188471
Sonork: 100.1676739
Thanks Meter: 22
chenge lcd ic
change LCD ic.....................
Old 02-11-2016, 04:07   #10 (permalink)
jimchu316's Avatar
Member: 2252373
Thanks Meter: 400
thank's before
the case was screw damaged
Old 02-27-2016, 00:12   #11 (permalink)
Member: 2252922
put qrong screw in board after no display at alll not even backlight ??????
Page generated in 0.18269 seconds with 9 queries
