Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-15-2017, 17:55   #1816 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by bayramkoc1903 View Post
hi a1490 ipad mini 2 icloud remove please please
How to unlock iCloud locked Apple iPad 2, iPad 3, iPad 4, iPad Air, iPad mini, iPad mini 2, iPad Air 2, iPad mini 3 - Pasha4ur Blog
Old 03-22-2017, 16:59   #1817 (permalink)
ozeltekno's Avatar
Member: 754364
Thanks Meter: 54
hi forum Friends , ipod A1574 Is icloud solution the scheme ?
Or any other solution program etc. Thanks
Old 03-22-2017, 22:11   #1818 (permalink)
Member: 2277735
Thanks Meter: 157
I'm shore a nand swap will work!
Old 03-23-2017, 11:46   #1819 (permalink)
Member: 2618537
Thanks Meter: 2
Hi,
After WIFI replacement on Air 2 4G (4G to WIFI) to iCloud removal, now WIFI panel says the network is strong but can't connect, only if i'm near the access point.
Any suggestions, friends?
Thanks
Old 03-23-2017, 20:21   #1820 (permalink)
Member: 2594641
Originally Posted by P3T3 View Post
China version if I'm correct there is no solution, if open please take some pics!
regards
I have not opened it yet as soon as I upload it
Old 03-23-2017, 21:09   #1821 (permalink)
Member: 2102980
do you have solution for ipad mini 4 gsm?
Old 03-26-2017, 10:53   #1822 (permalink)
Member: 2277735
Thanks Meter: 157
On Pasha blog he saying he need pics but I have not spoken to him so don't know if he still needs!
Old 03-28-2017, 00:53   #1823 (permalink)
Member: 2634857
Thanks Meter: 20
I have carried out the iPad Air 1475 Mod by removing the resistor R1506 it went clean no pulled pads.
It is now recognised as an iPad Air WiFi in iTunes which is all good, I have downloaded the model A1474 which is the WiFi version of the firmware and it gives errors 2005 on one machine, error 1349 on another and even u3tools fails at copying ramdisk at 20% .
Any ideas as to why this is not working? Could it be an older version of iTunes is needed ?
Picture of removed resistor.
Sent from my X98 Plus 3G using Tapatalk
Old 03-28-2017, 01:01   #1824 (permalink)
Member: 2634857
Thanks Meter: 20
Not enough posts for photo
Old 03-28-2017, 01:07   #1825 (permalink)
Member: 2634857
Thanks Meter: 20
Originally Posted by Bajwa786 View Post
I Pad Air 1475,
To all,
I do it with ipad Air 1475 I remove r 1506 Now my ipad in DFU mode but if i connect to itune so showing ipad,
But not restoring with ipad model software.
Error "ipad could not be restored because the firmware file was corrupt" ??
Hi Bajwa,
I have same A1475 and removed resistor and iTunes gives error 1349, another machine 2005, 2003 all fail even with u3tools fails at 20%.
Did you find the solution?
Kind Regards Darren
Old 03-30-2017, 13:39   #1826 (permalink)
Member: 2277735
Thanks Meter: 157
Clean your work, with air point needs to be very clean where resistor is removed... make shore nothing on board shorting, try restoring on Mac as well!
Old 03-30-2017, 13:58   #1827 (permalink)
Member: 2634857
Thanks Meter: 20
It was cable, tried 3 different ones and all had different resistances , bought a decent cable and flash done in ten mins.
Old 03-30-2017, 14:56   #1828 (permalink)
Member: 2693480
Smile
nice info. thank you will share about this
Old 03-30-2017, 19:28   #1829 (permalink)
Member: 2312714
Anything on A1550? I have one here...
Old 03-31-2017, 22:44   #1830 (permalink)
Member: 2701849
Okay, so I got an iCLoud locked A1460 updated to iOS 10.2.1
Was planning to remove the resistor but then I saw that I will loose WiFI, can someone confirm that?
If thatīs the case, only option is to wait for a JB before I do anything?
Page generated in 0.25307 seconds with 8 queries
