Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 11-05-2018, 10:38   #2416 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by Bscaine View Post
Hi, recently a new hardware came out to re-program nand on ipad 5,6:
Easy 56 adapter for ipad 5 and 6 non remove nand ic change sn
It's named easy 56 adapter. Where to buy this?
Success rate of these adaptors is around 1 in 6 (7 version of the air/2 don’t work), my friend had direct pc one and same problem(I have a navi3000 version)! Prepare to be disappointed!!
The Following User Says Thank You to P3T3 For This Useful Post:
Old 11-05-2018, 11:18   #2417 (permalink)
Member: 619511
Thanks Meter: 51
I have ipad air2 a1567 icloud lock. I want to unlock it. I want to confirm is it method remove resistor still work.
Thx
The Following User Says Thank You to ntek For This Useful Post:
Old 11-05-2018, 21:03   #2418 (permalink)
Member: 428283
Thanks Meter: 3
ipad mini 4 help icloud
Hi everyone how can I bypass icloud model A1550 please
The Following User Says Thank You to alex2007 For This Useful Post:
Old 11-09-2018, 16:16   #2419 (permalink)
Member: 2277735
Thanks Meter: 157
Thx
No you need to flash new details on iPad with nand programmer!
Old 11-17-2018, 03:35   #2420 (permalink)
Member: 2156547
Thanks Meter: 3
thank you a lot bro
I test on ipad 4 is ok
but Air1 and mini 2 now is not work more
may be need to be change the SN
The Following User Says Thank You to unlock365vn For This Useful Post:
Old 11-18-2018, 12:53   #2421 (permalink)
Member: 2465616
Thanks Meter: 6
Hi all, i am into icloud unlocking by software but now i want to get into icloud unlocking ipads through hardware. So my question is which is the most affordable nand programmer is in the market at the moment which works for all the ipad models available in the market.
The Following User Says Thank You to Ryan2469 For This Useful Post:
Old 11-21-2018, 23:44   #2422 (permalink)
amanvir's Avatar
Member: 231737
Sonork: 100.1606447
Thanks Meter: 161
Originally Posted by P3T3 View Post
Try with 3u tools, gives you output!
Yes I also tried with that but same thing.
Now if i want to put it back to the same iCloud locked condition what can i do for that ?
iPhone X user using Tapatalk Pro
The Following User Says Thank You to amanvir For This Useful Post:
Old 11-21-2018, 23:56   #2423 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 237
You'll need more than one to service all models. There is 3 platforms of idevice 32 bit 64 bit and PCIE. Navi Plus 3000s is nice for both 32 bit and 64bit nands amd isn't very expensive, easy to use unlike the WL priducts.
Sent from my SM-G530T1 using Tapatalk
The Following User Says Thank You to Stunman112 For This Useful Post:
Old 11-24-2018, 16:11   #2424 (permalink)
Member: 2438408
Thanks Meter: 369
Originally Posted by mcmihai003 View Post
This method not working anymore for 64bits devices (mini2,3,4, air1, air2,pro) since ~ oct 2017.
All cellular devices need to be converted to WIFI only (what you did) but also to reprogramm nand to valid combination.
how to convert sir i have ipad mini 4 ???????
The Following User Says Thank You to alexid For This Useful Post:
Old 11-29-2018, 14:02   #2425 (permalink)
Member: 2277735
Thanks Meter: 157
Remove the resistor, check first page!
If you have no nand programmers then no point as won’t activate!
Old 12-05-2018, 10:45   #2426 (permalink)
Member: 2691507
Thanks Meter: 94
For all iPad / one machine you can use ip box pcie version. It will work with both old and new NAND (32bit/64bit/pcie)
If you have the money WL works well too, but you need a machine per nand version.
The Following User Says Thank You to cisco2017 For This Useful Post:
Old 12-09-2018, 13:34   #2427 (permalink)
Member: 1609777
Thanks Meter: 50
Hello
i have ipad A1396 AND A1455 lock icloud if i remove r14?? it is work after restore with itunes or i must need reprogramm nand? thanks
The Following 2 Users Say Thank You to nabel_sweed For This Useful Post:
Old 12-09-2018, 18:00   #2428 (permalink)
Member: 2870691
Thanks Meter: 18
Originally Posted by nabel_sweed View Post
Hello
No need to reprogramm nand with A1455 and A1396.
Just restitue and enjoy
Envoyé de mon iPhone en utilisant Tapatalk
The Following User Says Thank You to Carocorp14 For This Useful Post:
Old 12-12-2018, 00:32   #2429 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 16
Originally Posted by fastmover View Post
Hello can anyone verify if this is true
Yes, its true, i'm experiencing the same problem trying to unlock 3 ipad air1, you need a genuine SN+MAC+BT info from a working and icloud free ipad.
Old 12-15-2018, 00:17   #2430 (permalink)
Member: 1847613
Sonork: 1624223
I have ipad mini 2 a1490
I’m sure I did the right thing, by removing #4 and jumper #2 to #3, DFU mode, and stuck at error 9. Is it because there are no difference between the cellular model, and wifi model for the ipsw.
Desperately need help
Page generated in 0.17277 seconds with 8 queries
