Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 12-09-2018, 19:00   #2431 (permalink)
Member: 2870691
Thanks Meter: 10
Originally Posted by nabel_sweed View Post
Hello
i have ipad A1396 AND A1455 lock icloud if i remove r14?? it is work after restore with itunes or i must need reprogramm nand? thanks
No need to reprogramm nand with A1455 and A1396.
Just restitue and enjoy
Envoyť de mon iPhone en utilisant Tapatalk
The Following User Says Thank You to Carocorp14 For This Useful Post:
Old 12-12-2018, 01:32   #2432 (permalink)
Member: 2014547
Sonork: 100.1665176
Thanks Meter: 15
Originally Posted by fastmover View Post
Hello can anyone verify if this is true
Yes, its true, i'm experiencing the same problem trying to unlock 3 ipad air1, you need a genuine SN+MAC+BT info from a working and icloud free ipad.
Old 12-15-2018, 01:17   #2433 (permalink)
Member: 1847613
Sonork: 1624223
I have ipad mini 2 a1490
Iím sure I did the right thing, by removing #4 and jumper #2 to #3, DFU mode, and stuck at error 9. Is it because there are no difference between the cellular model, and wifi model for the ipsw.
Desperately need help
Old 12-17-2018, 16:40   #2434 (permalink)
Crazy Poster
Member: 1621517
Sonork: PriZ.naK!
Thanks Meter: 3
hello .. A1490 after write ipad mini 2 wifi model firmware unable to activate. any ideas ?
Old 12-18-2018, 06:42   #2435 (permalink)
Member: 861495
Thanks Meter: 32
Originally Posted by Ryan2469 View Post
Hi all, i am into icloud unlocking by software but now i want to get into icloud unlocking ipads through hardware. So my question is which is the most affordable nand programmer is in the market at the moment which works for all the ipad models available in the market.
I have the Nand pro its cheap and works ok gets job done but not recomended I also have the jc pro1000s with the ipad adaptors and works great only with wifi versions so I dont have to unsolder nands I like it I recomend it just plug and play because removing nands alot of work and risky
Old 12-18-2018, 09:17   #2436 (permalink)
Member: 2863207
A1432 ? any sloution ?
Old 12-19-2018, 10:02   #2437 (permalink)
Member: 2277735
Thanks Meter: 141
None remove adaptor for iPad pros? Please show me a link!!
Old 01-01-2019, 13:45   #2438 (permalink)
Member: 2886410
Hey, got a Ipad Air cellullar (A1475) that R1506 is removed and changed SN and wifi & bt Mac and installed ios for wifi A1474 model but not geting past activation with iTunes. Its telling it cant activate and to put in simcard :/ any ideas?
Used JC Pro1000s and none remove adapter for Ipad 4,5,6 air 1 & 2 for changing sn, bt & wifi mac
Old 01-01-2019, 14:08   #2439 (permalink)
Member: 2277735
Thanks Meter: 141
You have not converted board to WiFi only, check you conversion and make shore itís correct, once correct you flash WiFi only firmware.. Becuse itís asking for a sim itís not converted to WiFi only.
Old 01-02-2019, 08:44   #2440 (permalink)
Member: 2479472
i hard bypassed my iPad air 1 by deleting the resistor or making a jump when pash4u released the workaround and the kids updated the iPad after iOS 11 and now it won't go through the update process when im trying to complete the update manually with a wifi only file it won't complete. Im guessing it has to do with the issue some mac numbers not matching or something like mcic??? was there a work around for that currently so i can get the ipad working again? thank you
Old 01-02-2019, 13:55   #2441 (permalink)
Member: 2277735
Thanks Meter: 141
Ok macs can be anything it will update (won’t activate), your issue is something with board I’D as if showing as WiFi it will take WiFi firmware. If it’s udating using sim fw then I’m not shore as if byasssd using pash site would flash WiFi firmware.
Old 01-12-2019, 05:58   #2442 (permalink)
Member: 2259457
Thanks Meter: 4
Hi everyone
I have an idea.. Idk if it's true
the converted 32bits iPads can officially activated with his old same S/N.. Means the server reorganize the S/N by the model
So what for exp if i put a nand ic of an icloud locked iphone 5 on ipad 4 wifi then restore 😎😁
Old 01-12-2019, 12:24   #2443 (permalink)
Member: 2277735
Thanks Meter: 141
It will flash and activate (most times) as I have flashed random serials for testing and most activated but no FaceTime or iMessage, thatís 32bit WiFi devices.
Old 01-13-2019, 14:41   #2444 (permalink)
Member: 2601612
Thanks Meter: 9
Is there checking icloud site by serial number available?
I used to checked serial number on iunlocker.net before, but now can't check it on or off by serial.
just wanna check icloud status by serial for ipad2,3,4,mini.
Old 01-14-2019, 15:58   #2445 (permalink)
Member: 2228539
Thanks Meter: 2
please help me with IPAD A1458 ICLOUD bypass by hardware
Page generated in 0.26416 seconds with 8 queries
