Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-05-2019, 10:57   #2521 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by sebbo2201 View Post
So I looked it up now:
My A1567 is on iOS 9.3.2
Does this method still work somehow then?
No becuse when bypassed you have to flash iOS 12 and it’s patched so won’t activated!
Old 04-07-2019, 02:51   #2522 (permalink)
Member: 1995710
Question
Hi all, thanks for the info
I managed to bypass the ipad air 2 4g. I did it by removing the HDD and changing the serial, Wifi, Bluetooth, and making the jumper to go into dfu. finally flashing the wifi firmware. However, wifi greyed out. how do i get wifi if there is no jb avaliablefor 12.2 firmware? thank you!
Old 04-07-2019, 04:07   #2523 (permalink)
Member: 2693145
http://forum.gsmhosting.com/vbb/f631/bypass-icloud-ipad-2-3-4-air-mini-mini-retina-3g
thanks itz very helpfull to us
Old 04-07-2019, 07:18   #2524 (permalink)
Member: 2893653
Thanks Meter: 2
Before to removing HDD and chip making jumper and flash if is it GSM after removing nand and write serial wifi and Bluetooth
Envoyé de mon moto g(6) en utilisant Tapatalk
The Following User Says Thank You to electroben16 For This Useful Post:
Old 04-07-2019, 19:58   #2525 (permalink)
Member: 1995710
Question Answered to Myself
I dont understand what you saying, but thanks. Now, i wanted to reply my own question because i found the answer . basically i need to swap the wifi ic because no jb right now, for the ipad air 2 the correct one is 339S0250. if you have different model then different ic..
Old 04-08-2019, 08:56   #2526 (permalink)
Member: 1789946
same things for ipad pro 4G ? i need to change ic wifi ?
Old 04-08-2019, 23:21   #2527 (permalink)
Member: 1995710
Yep, always 4g or simcard models need wifi ic.
Old 04-08-2019, 23:23   #2528 (permalink)
Member: 1995710
Now i have a question. What ipads the navi pro 3000 dont support?
The Following User Says Thank You to zzniceboyzz For This Useful Post:
Old 04-09-2019, 13:50   #2529 (permalink)
Member: 2277735
Thanks Meter: 157
iPad Pro up is not supported with navi3000
iPad Air 2 is last Ipad they support
The Following 2 Users Say Thank You to P3T3 For This Useful Post:
Old 04-11-2019, 08:33   #2530 (permalink)
Member: 2904736
Thanks Meter: 4
Hello everyone,
I need help with ipad mini 2. I never unlocked the cellular model of mini 2 and I have a question about wifi ic? Did I need to replace wifi ic or not? I have navi 3000s for serial change.
Until now I was unlocked ipad 2, 3, 4, mini 1, 2, air 1 and 2 but never unlock 64bit cellular so I need help
Thank you in advance.
Old 04-12-2019, 17:28   #2531 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by ackopk View Post
Hello everyone,
Air 2 up GSM to WiFi conversation you have to change WiFi ic... Rest you don’t have to any changes to WiFi ic!
Old 04-12-2019, 19:30   #2532 (permalink)
Member: 2904736
Thanks Meter: 4
Thank you. But I was learned that on heavier way . I am already removed ic , and move by accident two capacitor near wifi ic, C5013 and C5010 I think. I hope that wifi ic is not burned, nand is ok
Old 04-20-2019, 08:41   #2533 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 44
I remove iPad 2 WiFi model A1395 nand and try to reprogram it with Jc pro and it detected it but no info
Can I get solution to this problem?
Sent from my iPhone using Tapatalk
Old 04-22-2019, 11:26   #2534 (permalink)
Member: 2277735
Thanks Meter: 157
Pic of nand pads please! Have to tested other nands on the reader, make shore readers ok?
Old 04-23-2019, 09:09   #2535 (permalink)
GSM MOBILES's Avatar
Member: 1624770
Sonork: 1640429
Thanks Meter: 77
IPad mini a1490
Removed 4th resistor and 3th resistor was not there ,jumper 2th place
Restore in iTunes this error show
Can any one help me what mistake I have done
Page generated in 0.38438 seconds with 8 queries
