Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-23-2019, 10:51   #2536 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by GSM MOBILES View Post
IPad mini a1490
Removed 4th resistor and 3th resistor was not there ,jumper 2th place
Restore in iTunes this error show
Can any one help me what mistake I have done
Sent from my iPhone using Tapatalk
Read!!!!!!
You have iOS 12.x iPad, this is patched iOS 11 up!!
You have to write new details to the nand to activate!
The Following User Says Thank You to P3T3 For This Useful Post:
Old 04-23-2019, 14:59   #2537 (permalink)
Member: 2790571
Thanks Meter: 4
I have an iPad unlocked sn bt wifi, please add me to WeChat: Apple--Car
The Following User Says Thank You to appleGSX For This Useful Post:
Old 04-23-2019, 15:15   #2538 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
you have to program nand with new serial + wifi + bt
The Following User Says Thank You to saveriuccio26 For This Useful Post:
Old 04-25-2019, 09:58   #2539 (permalink)
Member: 1789946
Originally Posted by P3T3 View Post
Pic of nand pads please! Have to tested other nands on the reader, make shore readers ok?
i have same problem on ipad air wth jc pro, i dont know waht is the problem
The Following User Says Thank You to racim-isn0w For This Useful Post:
Old 04-25-2019, 11:06   #2540 (permalink)
Member: 1789946
Originally Posted by jiiko2361 View Post
Can someone kindly tell me what wifi ic is for Pro 10.5 9.7, iPad5 2017?
Pro10.5 and 2017 is same wifi ic?
Thanks.
neet to know also
Old 04-29-2019, 16:19   #2541 (permalink)
Member: 2904736
Thanks Meter: 2
Hi guys, can you recommend me a nand programmer for ipad pro models?
Old 04-29-2019, 16:34   #2542 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 782
check if your serial is icloud off and/or fmi clean, if ok format nand and create partitions , rewrite new s/n info ACTIVE ONLY IN WIFI MODE NO CONNECT DIRECTLY to pc with itunes.
The Following User Says Thank You to orx For This Useful Post:
Old 04-30-2019, 10:59   #2543 (permalink)
Member: 2277735
Thanks Meter: 157
If not working make shore details are correct after write, use 3u tools to got logs!
Old 05-02-2019, 11:23   #2544 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
good morning
someone has nand list not supported with adapter for ipad 5/6
naviplus pro 3000s
Old 05-05-2019, 04:08   #2545 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
Hello
i have an ipad air 2 4g turned into wifi with ios 12
I made the jailbreak I changed the wifi driver but it does not activate.
this method does not work on ios 12
Old 05-06-2019, 11:19   #2546 (permalink)
Member: 2907377
Thanks Meter: 2
Where do you check? Support site / send repair? I have been able to activate via itunes after using non removal for 4/5/6
Old 05-06-2019, 14:00   #2547 (permalink)
Member: 2904736
Thanks Meter: 2
Can anybody recommend nand programmer for pro models, 5th and 6th model (2017 and newer)?
Old 05-06-2019, 14:14   #2548 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 782
i mean of to check serial if it's ok through online service ..and for my experience i've always activated with wifi after to have reprogrammed nand with no removal tool this because directly with itunes i had activation problem.
Old 05-06-2019, 14:25   #2549 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 782
list non supported nands IPAD AIR / AIR 2
JC ADAPT:
32G THGBX2G8D4JLA01
32G THGBX2G8B4JLA01
32G THGBX3G8D4KLA0C
32G H2JTEG8VD1CMS
64G THGBX4G9T4KLF0C
64G H2JTFG8PD1MMR
NAVIPLUS :
32G THGBX2G8D4JLA01
32G THGBX2G8B4JLA01
32G THGBX3G8D4KLA0C
32G H2JTEG8VD1CMS
64G THGBX4G9T4KLF0C
64G H2JTFG8PD1MMR
EASY56 ADAPTER:
SDMILBCF4
THGBX4G9T4KLF0C
H2JTFG8PD1MMR
maybe others...
Nand pro with adapter seems to be the only tool to support fuc***ng nand toshiba 32/64 gb
Old 05-06-2019, 20:11   #2550 (permalink)
Member: 2904736
Thanks Meter: 2
Please, I need help. I need to unlock air 2 with 32gb, I change serial on naviplus but when I put board in ipad and do restore I get old serial number
I check three times and always get good serial on programmer and old bad serial when turn on ipad.
Thanks in advance.
Page generated in 0.15490 seconds with 8 queries
