Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-06-2019, 20:11   #2551 (permalink)
Member: 2904736
Thanks Meter: 4
Please, I need help. I need to unlock air 2 with 32gb, I change serial on naviplus but when I put board in ipad and do restore I get old serial number
I check three times and always get good serial on programmer and old bad serial when turn on ipad.
Thanks in advance.
Old 05-06-2019, 21:27   #2552 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
how do you write the nand
Old 05-06-2019, 21:32   #2553 (permalink)
Member: 2904736
Thanks Meter: 4
Over non-removing adapter with naviplus 3000s.
Old 05-06-2019, 21:44   #2554 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
does the nand recognize it?
see some nand are not compatible
check the settings well and if activated pad 5/6 unremoving
Old 05-06-2019, 21:45   #2555 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
32g thgbx2g8d4jla01
32g thgbx2g8b4jla01
32g thgbx3g8d4kla0c
32g h2jteg8vd1cms
64g thgbx4g9t4klf0c
64g h2jtfg8pd1mmr
Old 05-06-2019, 21:53   #2556 (permalink)
Member: 2904736
Thanks Meter: 4
Naviplus recognize nand. Everything is ok when I read and write serial code but when conect ipad with PC (3uTool) I get old serial number. When I want to activate ipad he recognize old icloud ID
Old 05-06-2019, 22:11   #2557 (permalink)
Member: 2904736
Thanks Meter: 4
@edit:
hmmm... when I read nand naviplus says that nand is h2jteg8vd1cms but I was look on board and text on nand is "h2jteg8vd1cmr'
Old 05-06-2019, 22:22   #2558 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
if he always reads the old serial
means he doesn't write it
Old 05-06-2019, 22:26   #2559 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
https://www.youtube.com/watch?v=pwnLOuhdlQE
The Following User Says Thank You to saveriuccio26 For This Useful Post:
Old 05-07-2019, 06:57   #2560 (permalink)
Member: 2904736
Thanks Meter: 4
Thanks for video. I was check settings on naviplus, it's ok.
Always get good serial on naviplus but wrong serial when I need to activate ipad.
Old 05-07-2019, 07:42   #2561 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 785
Thanks in advance.
above the list with non supported Nands check , if your nand result ok so result to be compatible , format nand ,rebuild and rewrite new serial then restore and active using wifi not itunes.
The Following User Says Thank You to orx For This Useful Post:
Old 05-07-2019, 07:47   #2562 (permalink)
Member: 2904736
Thanks Meter: 4
Can I format nand with non-removing adapter? Or I need to take off nand from board?
Orx, why naviplus see one nand code and on nand I see different code? Naviplus see h2jteg8vd1cms but on nand I see code h2jteg8vd1cmr (see picture in post above)
Always use 3uTool and wifi activating.
Old 05-07-2019, 07:52   #2563 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
you can't format with adapter
you have to remove
Old 05-07-2019, 08:21   #2564 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 785
hi
Naviplus is good with chip-off but with adapter in the past i had problems with old ipads ..now i use Jc adapt and with Jc adapter you can to format the nand ..i presume that your nand is not compatible even if it is not on the list so at this point i think that one solution is chip-off if not exist or is not possible format option..sorry but I have no more naviplus and I don't remember well if it is possible to format with adapter but if Saveriuccio said this is possible it is so .
Old 05-07-2019, 08:27   #2565 (permalink)
Member: 2904736
Thanks Meter: 4
Thanks a lot guys, I will take off nand I try to format and write new information.
The Following User Says Thank You to ackopk For This Useful Post:
Page generated in 0.14598 seconds with 8 queries
