Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-23-2019, 08:01   #2596 (permalink)
Member: 1643783
Sonork: red
Thanks Meter: 7
Any update for removing icloud on ipadmini4 with sim slot?
Old 07-25-2019, 07:18   #2597 (permalink)
Member: 88304
Thanks Meter: 7
what update are you waiting for?
disassemble ipad, change wifi ic, write sn+macs to nand and it works
The Following User Says Thank You to $ide$tep For This Useful Post:
Old 08-15-2019, 07:57   #2598 (permalink)
Member: 2601612
Thanks Meter: 14
after remove icloud by changing SN+macs,
have you guys ever experient some other icloud account ON (which is not original account) locked, when resetting your device after a few days or months?
i got many these situations. and have to work again.
how to handle this problem?
The Following User Says Thank You to jiiko2361 For This Useful Post:
Old 08-15-2019, 07:58   #2599 (permalink)
Member: 2601612
Thanks Meter: 14
i got many these situations. and have to work again. I'm sure that someone buy exactly same SN from seller and over write it.
how do you guys handle this problem? have to create many icloud account?
Old 08-15-2019, 20:47   #2600 (permalink)
Member: 2277735
Thanks Meter: 157
When you check details on iCloud check dos it say from reseller or something like that? If not sounds like they get details from original iPad, delete iCloud, sell details then activate the iCloud on original that will lock it!!
Get your details from legit sellers and you won’t have this issue.
Old 08-17-2019, 14:26   #2601 (permalink)
Member: 2904736
Thanks Meter: 6
Where to find legit sellers?
Old 08-19-2019, 00:51   #2602 (permalink)
Member: 2203193
Thanks Meter: 23
Ios 12.4 jailbreak is out today by uncover...any one have solutio for ipad air 2 grey wifi after convert to wifi model. I read its posible via jailbreak intead of change wifi ic
The Following User Says Thank You to abu-zaid For This Useful Post:
Old 08-19-2019, 00:53   #2603 (permalink)
Member: 2203193
Thanks Meter: 23
My another question wana buy tool for pcie nand for work on ipad pro models
Which one is best
Old 08-22-2019, 11:04   #2604 (permalink)
Member: 1699006
Thanks Meter: 71
A1430 bypass not work anymore
Old 08-23-2019, 18:32   #2605 (permalink)
Crazy Poster
Member: 1853844
Thanks Meter: 6
it still works on a1430
Old 08-25-2019, 18:43   #2606 (permalink)
Member: 1699006
Thanks Meter: 71
In mine case after remove r1204 and flash with 9.3.5 will not work
Asking again for Apple ID
Old 08-26-2019, 15:39   #2607 (permalink)
Member: 2601612
Thanks Meter: 14
it still works.
I guess that someone used your SN of Wi-Fi ver either. if still ID there, you can work with NAND just like Wi-Fi ver.
Old 08-26-2019, 15:47   #2608 (permalink)
Member: 2601612
Thanks Meter: 14
On iOS12.4,
when login Apple ID, Message pop up (Facetime can't activate, contact to apple service).
i know this facetime issue from before. but I don't want this message. how can i handle this?
Old 08-26-2019, 20:37   #2609 (permalink)
Member: 2162350
Thanks Meter: 5
I have original a1567 ipad air 2 bypassed via resistor on iOS 10.2. I upgraded to 12.4 via OTA and it works except wifi is greyed out. I did jailbreak and replaced wifi files in folder C-4350__s-C2 but wifi still does not work. Maybe these files are NOT compatible with iOS 12 and need new files. I tried to get the files myself from another iPad air 2 1567 but they appeared to be the same and didn't work.
I know I can change the wifi IC but I don't want to damage it. Wifi files easier..
NEED HELP.
Old 08-27-2019, 11:21   #2610 (permalink)
Member: 1699006
Thanks Meter: 71
it still works.
A1430 was at another store before they come to me.
After disassembling i saw that both R1204 and R1205 removed.
Flashing WO R1204-R-1205 Resistors will ask For Apple ID.
I Found A1458 and took 2x R with 10K -32W - 5% - 01005 - MF
If i Replace only R1204 for A14300 it will fail flashing
If i Replace only R1205 it will recognized as A1403 and fail flashing
If i replace both of them Ipad is Unknown
Nothing else has been touched like WIFI NAND or other
any Suggestion ?
Page generated in 0.19605 seconds with 8 queries
