Data recovery by ipbox hi, is it possible to recover data in the nand by ipbox? Is it possible when the board is dead? thanks |
it's not possible... encrypted by cpu |
ok thanks for your answer. same problem to install the nand on another board? thanks |
hi, nobody can help me? do you have a tutorial for use ipbox2? |
the data stored on the nand uses the cpu key i believe, the nand must be wiped to pair to a new cpu. I would suggest board repair to recover data. If you just want to use the nand without data, load to ipbox v2, test disk, if ok extract data. check all 5 boxes and press write (this will enable pairing but warning any data is removed) |
