03-20-2015, 17:04 | #1 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2365884 Status: Offline Thanks Meter: 0 | Earpiece Volume Very Low after Screen Replacement The install went fairly well (those screws are tiny!). Everything works well, except the earpiece volume is extremely low. I can barely hear from the earpiece which tells me that the speaker actually works, but it's barely audible. I've rebooted the device several times and I've tried cleaning all of the speaker covers. Could it be that one of the three tiny cables has come loose? I didn't think those three cables were for the earpiece. Everything else works fine so wouldn't think it would be a cable connection issue. Any ideas? Thanks. |
03-20-2015, 23:52 | #2 (permalink) |
Freak Poster Join Date: Jun 2013
Member: 1952487 Status: Offline Thanks Meter: 43 | hello, probably the earpiece it self is bad, just replace this earpiece with the old one, waiting for your replay. |
The Following User Says Thank You to arvaser For This Useful Post: |
03-23-2015, 02:26 | #3 (permalink) |
Member: 2365884 Status: Offline Thanks Meter: 0 | Thanks. I did that and it did not help. I also replaced the tiny cable from the old phone. The sound is barely audible even at the max setting. This was my daughter's old phone and she told me after my initial post that the earpiece was not working after she dropped it and the screen cracked. |
03-23-2015, 15:10 | #4 (permalink) |
Junior Member Join Date: Jan 2009
Member: 943277 Status: Offline Thanks Meter: 5 | i had this problem before. turned out there was a small piece of plastic film over the earpiece mesh on the new display. Removed it and it was all good. hope this helps |
The Following User Says Thank You to wickywicky For This Useful Post: |
03-23-2015, 16:00 | #5 (permalink) |
Member: 2365884 Status: Offline Thanks Meter: 0 | Wicky, thanks. I heard about that fix and I even removed the mesh screen completely and made sure that nothing was over the screen and the volume is still barely audible. Until I upgrade my other daughter's phone (and I'll get her iPhone 5) later this year I'll use bluetooth, an earphone cable, or the speaker. I'm in an office all day so I rarely use the phone at work. |
