Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-14-2011, 12:29   #16 (permalink)
Member: 1508411
Thanks Meter: 36
Right, I'll check the battery this evening and replace it with a brand new one and let you know. Is this something to do with the Gas Gauge
on the battery?
Old 09-14-2011, 12:42   #17 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,544
on the battery?
Yes yes yes bro that's it.
Old 09-14-2011, 18:39   #18 (permalink)
Member: 1508411
Thanks Meter: 36
New Battery, same problem :-(
Old 09-14-2011, 19:21   #19 (permalink)
Member: 1017374
Thanks Meter: 2,544
What caused problem water/foll/dropped/restore/fake charger???
Old 09-14-2011, 19:29   #20 (permalink)
bootgsm's Avatar
Member: 527800
Thanks Meter: 233
i had and i have the same problem
i think your IMEI is damaged
if you want to chek that you need to restor you iphone using
iPhone3,1_4.3.5_8L1_Custom_Pwnage.Tool_Restore_Act ivated.ipsw
you can find it here http://hotfile.com/list/1834925/f6ab5eb
your phone will start but no imei no wifi etc
Old 09-14-2011, 20:02   #21 (permalink)
PANTECH N B R's Avatar
Member: 927663
Thanks Meter: 39
Errors -9815
Set exact date, restart computer. See also Apple's KB article.
Errors -9814
Errors -9800
Error -50
Delete Storm Vedio, QuickTime, iTunes, then reinstall iTunes. See also Apple's KB article.
Error -35
See Apple's KB article.
Error 1
Unable to downgrade. Try changing the USB port (the back one of chassis is better) and restart computer.
The installed version of iTunes may also be too old. Update iTunes.
Error 2
Sn0wbreeze 1.6 Custom Firmware has a ASR patch problem. Use sn0wbreeze 1.7 or PwnageTool. Device isn't bootable.
Error 6
Not enter the downgrading mode, change USB port (the back one of chassis is better) and restart computer.
Error 10
LLB is missing from the IPSW. The device cannot be booted up. The trick to skip the baseband update no longer works.
Error 11
Removed bbfw file in the firmware folder of an unzipped IPSW.
Error 13
Occurs when you want to install a beta firmware with iTunes for Windows (actively blocked by Apple; beta users are developers and therefore must have a Mac).
Error 13 may also signify a USB problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable.
Error 14
Custom firmware update fail (PwnageTool). You have to restore the device with a custom firmware. Update to a custom firmware isn't working. Device isn't bootable. 2
USB Problem. Check the USB connection and try other direct ports or maybe the USB cable is an older one. Device isn't bootable.
Error 17
Custom firmware update fail (sn0wbreeze). You have to restore the device with a custom firmware. Update to a custom firmware isn't working. 2
Error 20
Searching correct fault.
Error 23
Error 26
False version of the NOR flash firmware. Use the correct sn0wbreeze version.
Error 29
See Apple discussions thread about this problem.
Error 37
iPod touch 2G LLB patched with the 0x24000 Segment Overflow was used on an iPhone 3GS custom firmware. Known on damaged bundles from unofficial PwnageTool distributions or bundles.
Error 1002
Are you restoring to a stock apple firmware or a custom pwn firmware? Either way make sure you are in DFU mode first.
Error 1004
This is caused by a failure to match the Baseband Nonce currently in memory to the Nonce returned in the BasebandFirmware SHSH blob. This is a normal part of iPhone 4 local restores via TinyUmbrella. 1
Error 1013
Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.0.2 firmware downgraded from 1.1.1)
Error 1014
This error is down to itunes not liking your USB ports on your computer. Use a different USB slot or a different computer if possible. That is the easiest fix!
Error 1015
Restart computer; change computer; reinstall system, if iPhone is always in restoring mode: XP users can jump from restoring mode with ibus; MAC users can use iNdependence. (usually on the iPhone with 1.1.1 firmware downgraded from 1.1.2) Baseband firmware on the IPSW is higher than the baseband firmware on the iPad/iPhone. 1
Error 1413
Restart computer; change USB port; reinstall system. See also Apple's KB article.
Error 1415
Error 1417
Error 1418
Error 1428
Error 1600
Custom firmware can't be restored on a device with DFU Mode. Use Recovery Mode.
Error 1602
Restart computer; change computer; reinstall system.
Error 1603
False kernelcache patch. Known on damaged bundles from unofficial PwnageTool distributions or bundles. See also Apple KB article
Error 1604
Device was not pwned (signature checks were not blocked). Custom firmware can't be restored.
Error 1611
iTunes tried to enter the Restore Mode, but the device turned back to the Recovery Mode.
Error 1619
iTunes is too old and couldn't read the iPhone in Recovery or DFU Mode. Please update iTunes and try it again.
Error 1644
IPSW was moved during prepare with iTunes. Try it again and don't move the IPSW.
Error 2002
iTunes can't connect because another program is using it or it's disconnected during the Apple Server check.
Error 3XXX
iTunes can't connect to gs.apple.com. Maybe Port 80 and Port 443 is blocked. Open it on your router.
Error 3002
Update to an older firmware isn't working, because Apple is no longer handing out SHSHs for the device/firmware combination.
Error 3004
No internet connection during the firmware restore.
Error 3014
False edited hosts. The SHSH request couldn't be completed. No connection to the Apple Server, Sauriks Server or localhost.
Error 3194
Occurs when trying to install an old firmware and Apple's server disallows the installation. The only solution is to have SHSH backup and modify the hosts file to point to Saurik's Cydia server where they are backed up (or localhost if you have it yourself).
Error 3195
"An internal error occurred." Missing SHSH for the firmware. Maybe the same as "This device isn't eligible for the request build." but with an cache error.
Error 11222
internet options Connections tab Click LAN Settings uncheck "use a proxy server"
0xE8000022
Searching..........
0xE800003D
False permissions in the Carrier Bundle folder. Restore, update or fix the permissions from the carrier bundle to update the carrier settings via iTunes.
0xE800006B
Device was suddenly unplugged. iTunes couldn't connect with the device. Try it again.
0xE8000065
sn0wbreeze custom cirmware error on USB connection. Unplug the device, reboot it, and plug it in again.
Old 09-14-2011, 21:49   #22 (permalink)
Member: 1508411
Thanks Meter: 36
We all know what the error code means, we are looking for alternatives.
3194, trying to update firmware to latest 4.3.5 not downgrade!
1013, tried all the usual suggestions relating to this error.
It has to be hardware.
Old 09-16-2011, 11:27   #23 (permalink)
Member: 1508411
Thanks Meter: 36
Tried this custom software,
error 21, in recovery mode and error 1600 in DFU
Old 09-16-2011, 14:35   #24 (permalink)
Member: 1017374
Thanks Meter: 2,544
What caused this problem that it have no imei,BB,wifi???
Old 09-16-2011, 15:55   #25 (permalink)
Member: 1575322
Sonork: 432503199012184011
hi
use TinyUmbrella put up servers and you need the shsh. backups
then installing you iphone
i'm sorry my english is no good
Old 09-19-2011, 10:02   #26 (permalink)
bootgsm's Avatar
Member: 527800
Thanks Meter: 233
don't make manual recovery , do it using IREB
Old 09-19-2011, 22:08   #27 (permalink)
Member: 1656882
Thanks Meter: 2
guyes for error 1013 use i reb4
Old 09-19-2011, 22:10   #28 (permalink)
Member: 1656882
Thanks Meter: 2
any help come and use TeamViewer 6 my id is [email protected] or yahoo.com
Old 09-20-2011, 11:22   #29 (permalink)
Member: 1508411
Thanks Meter: 36
I'll try iReb 4 this eve and report back
Old 12-07-2017, 15:28   #30 (permalink)
Member: 170102
Thanks Meter: 3
error itunes
iphone 6g does not connect but connects on itunes initiates restore and acknowledges error (40) then 0xe000065
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 20:18
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.48053 seconds with 8 queries
