Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 05-26-2014, 01:50   #76 (permalink)
Member: 107989
Thanks Meter: 3
Hi
Remove Front Camera Flex from mainboard and Flash it.You must change the
Front Camera Flex by Original. Error 4013 is from Camera.
Old 05-27-2014, 13:27   #77 (permalink)
Member: 751586
Sonork: 0858412346
Thanks Meter: 52
some body tell me change proximity sensor Flex. change cable and battery change wifi ic but not success i try check voltage baseband chiip but no have problem point
Now .. no success for me
Old 07-23-2014, 16:46   #78 (permalink)
Member: 1759455
Thanks Meter: 9
Some people say: Its baseband IC, but the other says: Its camera 100% solution, the other says: Its wifi IC, so, WTF is the REAL solution ?
Old 07-23-2014, 19:56   #79 (permalink)
Member: 40262
Thanks Meter: 11
No baseband chipid reported you understand?Check voltage and reported us.Remove all flex from motherboard and try reflash.If you have still error than check voltage to baseband chip.If voltage to low or not than problem with short cap or voltage regulator ic.
Old 07-24-2014, 01:22   #80 (permalink)
Member: 220595
Thanks Meter: 355
I was receiving this error 4013 on 4s restoring to 7.1.2 with latest itunes 11.3
I disconnected almost all flex cables from Board and tried to restore in dfu mode, I no longer receive the 4013 error as long as flexes are removed but I am receiving now error 2009
on log I can read:
[00:08:50.0599] Creating timer to monitor transition
 [00:08:50.0930] AMDeviceIoControl: failed, error 2, usbd status c0000011
 [00:08:51.0430] AMDeviceIoControl: failed, error 2, usbd status c0000011
 [00:08:51.0931] USBControlTransfer: error 2, usbd status c0000011
 [00:08:51.0931] command device request for 'ticket' failed: 2009
 [00:08:51.0931] device rejected ap ticket (2009)
 [00:08:51.0931] AMRAuthInstallDeletePersonalizedBundle
 [00:08:52.0119] Restore completed, status:2009
[00:08:52.0119] Failure Description:
[00:08:52.0119] Depth:0 Error:Failed to restore device in recovery mode, libusbrestore error:2009
any idea for this error?
Old 07-24-2014, 08:48   #81 (permalink)
Member: 40262
Thanks Meter: 11
on log I can read:
U2 change.Its USB ic problem
Old 07-24-2014, 18:00   #82 (permalink)
Member: 220595
Thanks Meter: 355
My mistake...
I was trying to debug de 4013, and when I disconnected all flex I got the other error, At this point I thought: I bypassed the 4013 error, But I was wrong, I just got this new error and I thought it was a second, just that it became the first.
After Y solved the 2009 error by changing the phone to a different usb port I got the 4013 error Again
so am in the same place (beginning) and I am also reading the baseband error in the logs.
Old 07-24-2014, 18:52   #83 (permalink)
Member: 1042806
Thanks Meter: 5
contact me to have a solution .yahoo messenger quoc_binhthuan
Old 07-25-2014, 00:28   #84 (permalink)
Member: 220595
Thanks Meter: 355
SOLVED!
I dismantled the phone and clean the PCB with alcohol for a long time on UltraSound Cleaner machine.
Phone is now running 7.1.2, just restored.
This worked for me, I dont know if it will work for others, but you can give it a try !
perhaps some dust were sit under Baseband chip shorting it or something.
@tuvinh599
post your solutions in thread, so others can test it and comment in the community...
Thanks button is just there...
Old 07-26-2014, 15:14   #85 (permalink)
Member: 1961124
Thanks Meter: 3
My mistake...
my friend your problem may be NAND getting low power check the side of U4 capacitor current for 1000ma ,3vI/O and at top of U4 500ma,1.8. If recovery progress bar stuck at 0% or 5% problem is NAND
Old 12-09-2014, 17:41   #86 (permalink)
Member: 1999993
The most common problem causing this error is an bad proximity cable. Try changing this cable but before installing a new one, restore the iphone to the latest iOS and then install the new proximity cable. For most people having this problem it worked.
Old 12-09-2014, 18:20   #87 (permalink)
Member: 1742913
Sonork: 100.1604070
Thanks Meter: 328
no need change wifi ic. or basband chip. this problum(4013) i get more than10 pcs. i did sucsessfull. contact me privet
br,
The Following User Says Thank You to android unbrik For This Useful Post:
Old 12-29-2014, 19:55   #88 (permalink)
Member: 1384112
Sonork: 143
tel me ur mobile number.... 919377744464 contact me..plz tel me solution 4s 4013 error
Old 02-05-2015, 03:32   #89 (permalink)
Member: 2020644
Sonork: myalexp
Thanks Meter: 2
I solved this problem..error 4013 in iPhone 4s..this step i give you maybe can help..
1. Rehot wifi ic with hot water 350 c. Don forget to give flus before rehot
2. Rehot emmc
3. Restore only with flex dock & battre..
I resolve this problem eith many iphone..maybe can help..
Old 02-05-2015, 17:22   #90 (permalink)
Member: 220595
Thanks Meter: 355
are you sure you are talking about how water and not hot air?
can you place a pcb picture marking exactly the ICs you rehot ?
Page generated in 0.22908 seconds with 9 queries
