05-27-2014, 13:27 | #77 (permalink) |
Freak Poster Join Date: Apr 2008 Location: thailand
Member: 751586 Status: Offline Sonork: 0858412346 Thanks Meter: 52 | some body tell me change proximity sensor Flex. change cable and battery change wifi ic but not success i try check voltage baseband chiip but no have problem point Now .. no success for me |
07-23-2014, 19:56 | #79 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Poland Age: 57
Member: 40262 Status: Offline Thanks Meter: 11 | No baseband chipid reported you understand?Check voltage and reported us.Remove all flex from motherboard and try reflash.If you have still error than check voltage to baseband chip.If voltage to low or not than problem with short cap or voltage regulator ic. |
07-24-2014, 01:22 | #80 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | I was receiving this error 4013 on 4s restoring to 7.1.2 with latest itunes 11.3 I disconnected almost all flex cables from Board and tried to restore in dfu mode, I no longer receive the 4013 error as long as flexes are removed but I am receiving now error 2009 on log I can read: Code: [00:08:50.0599] Creating timer to monitor transition [00:08:50.0930] AMDeviceIoControl: failed, error 2, usbd status c0000011 [00:08:51.0430] AMDeviceIoControl: failed, error 2, usbd status c0000011 [00:08:51.0931] USBControlTransfer: error 2, usbd status c0000011 [00:08:51.0931] command device request for 'ticket' failed: 2009 [00:08:51.0931] device rejected ap ticket (2009) [00:08:51.0931] AMRAuthInstallDeletePersonalizedBundle [00:08:52.0119] Restore completed, status:2009 [00:08:52.0119] Failure Description: [00:08:52.0119] Depth:0 Error:Failed to restore device in recovery mode, libusbrestore error:2009 |
07-24-2014, 08:48 | #81 (permalink) | |
Member: 40262 Status: Offline Thanks Meter: 11 | Quote:
07-24-2014, 18:00 | #82 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | My mistake... I was trying to debug de 4013, and when I disconnected all flex I got the other error, At this point I thought: I bypassed the 4013 error, But I was wrong, I just got this new error and I thought it was a second, just that it became the first. After Y solved the 2009 error by changing the phone to a different usb port I got the 4013 error Again so am in the same place (beginning) and I am also reading the baseband error in the logs. |
07-25-2014, 00:28 | #84 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | SOLVED! I dismantled the phone and clean the PCB with alcohol for a long time on UltraSound Cleaner machine. Phone is now running 7.1.2, just restored. This worked for me, I dont know if it will work for others, but you can give it a try ! perhaps some dust were sit under Baseband chip shorting it or something. @tuvinh599 post your solutions in thread, so others can test it and comment in the community... Thanks button is just there... |
07-26-2014, 15:14 | #85 (permalink) | |
Junior Member Join Date: Jun 2013
Member: 1961124 Status: Offline Thanks Meter: 3 | Quote:
12-09-2014, 17:41 | #86 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1999993 Status: Offline Thanks Meter: 0 | The most common problem causing this error is an bad proximity cable. Try changing this cable but before installing a new one, restore the iphone to the latest iOS and then install the new proximity cable. For most people having this problem it worked. |
12-09-2014, 18:20 | #87 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: bahrain.
Member: 1742913 Status: Offline Sonork: 100.1604070 Thanks Meter: 328 | Quote:
br, | |
The Following User Says Thank You to android unbrik For This Useful Post: |
02-05-2015, 03:32 | #89 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2020644 Status: Offline Sonork: myalexp Thanks Meter: 2 | I solved this problem..error 4013 in iPhone 4s..this step i give you maybe can help.. 1. Rehot wifi ic with hot water 350 c. Don forget to give flus before rehot 2. Rehot emmc 3. Restore only with flex dock & battre.. I resolve this problem eith many iphone..maybe can help.. |
