Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-24-2013, 08:48   #1 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
Exclamation Error 4013 ????
Anyone seen this before ??? error 4013 after upgrading to ios 7, I have 2 Iphone 5 With the same problem !!
Old 09-24-2013, 09:30   #2 (permalink)
Member: 2002240
Thanks Meter: 2
Check iTunes logs:
win7- C:\Users\<UserName>\AppData\Roaming\AppleComputer\ Logs
C:\Users\<UserName>\AppData\Roaming\Apple Computer\iTunes\iPhone Updater Logs
winXP- C:\Documents and Settings\<UserName>\Application Data\Apple Computer\iTunes\Logs
C:\Documents and Settings\<UserName>\Application Data\Apple Computer\iTunes\iTunes\iPhone Updater Logs
Last lines can explain the problem.
Have you tried update on another computer?
I had a 4012 error and it was coused by errors at the windows registry. On another computer it worked perfectly
The Following User Says Thank You to mlodykuba For This Useful Post:
Old 09-24-2013, 09:36   #3 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
Yes i already tried on different Pc ... the Same Error happened
Old 09-24-2013, 09:59   #4 (permalink)
Member: 2002240
Thanks Meter: 2
Ok, check logs and paste (if it is accptable) here couple last lines.
Check also CrashReporter files (in the Logs directory).
Before updating phones worked normally?
Old 09-24-2013, 10:17   #5 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
transition
[07:55:20.0696] RestoreOS mode device connected
[07:55:20.0696] Transitioning device returned, continuing restore.
[07:55:20.0698] Canceling timer
[07:55:20.0698] Changing state from 'Transitioning' to 'Restoring'
[07:55:20.0706] <Restore Device 052174F0>: operation 44 progress -1
[07:55:20.0707] requested restore behavior: Erase
[07:55:20.0708] requested variant: Erase
[07:55:20.0710] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
Old 09-24-2013, 10:19   #6 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
is 4013 the same as the -1 ?
The Following User Says Thank You to Ifonefreak For This Useful Post:
Old 09-24-2013, 10:41   #7 (permalink)
Member: 2002240
Thanks Meter: 2
Have you got a newest iTunes version?
Both phones worked normally before updating?
Have you tried dowload iOS 6.1.3 and restore "manually" (with shift key)?
Old 09-24-2013, 10:48   #8 (permalink)
Member: 1873863
Thanks Meter: 67
Yesterday i have updated to latest iTunes and now trying to upgrade a 4S i have an error 4014 (before it was -1 so i think is the same)
Old 09-24-2013, 11:16   #9 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
Yes man .. Everything was Normal .. I think is the same Error as -1
Old 09-24-2013, 13:05   #10 (permalink)
Member: 2002240
Thanks Meter: 2
Move or rename hosts file (c:\windows\drivers\etc). Change the cable. Try to restore manually
Old 09-24-2013, 13:42   #11 (permalink)
Member: 40262
Thanks Meter: 11
I cant restore 3GS please look in log
[VFL:ERR] VFL_ReadBBT(wCS:1)(line 1753) fail!
[WMR:ERR] VFL_Open failed
AppleNANDLegacyFTL::start: AND init failed
NAND driver status = failed
NAND driver status indicates failure
Error 40 I cant fix.
Old 09-24-2013, 14:10   #12 (permalink)
Member: 2002240
Thanks Meter: 2
You sure that hardware is ok? Was this phone dropped? You can try hint with hosts file. If it isn't hardware problem that means iTunes can't connect to apple update server. Check also your firewall settings.
Old 09-25-2013, 11:54   #13 (permalink)
huahaonam's Avatar
Member: 890799
Sonork: 100.999999
Thanks Meter: 319
ME,Too, I need Solution
Old 09-26-2013, 01:00   #14 (permalink)
Member: 180123
same problem iphone 4 error 4013
need solution
Old 09-26-2013, 07:05   #15 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
I got 3 Iphone 5 with the same error!!
Page generated in 0.55481 seconds with 7 queries
