Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 09-26-2013, 07:24   #16 (permalink)
Member: 1486413
Thanks Meter: 5
iphone 5 error 4013?? no solution
The Following User Says Thank You to anujgaba For This Useful Post:
Old 09-26-2013, 19:40   #17 (permalink)
Member: 2002240
Thanks Meter: 2
Is this error occurs also when you try to restore manually?
http://forum.gsmhosting.com/vbb/f812...nload-1511373/ - here you find all firmware versions.
If removing the hosts file and turning off firewall doesn't help try uninstall iTunes with all components Removing and reinstalling iTunes and other software components for Windows Vista, Windows 7, or Windows 8 check also available free space - iOS 7 is about 300mb more than 6.1.4
The Following User Says Thank You to mlodykuba For This Useful Post:
Old 09-27-2013, 07:25   #18 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
I guess it is Hardware Solution ..
Old 09-27-2013, 12:49   #19 (permalink)
Member: 1899870
Same problem hardware problem sure
Old 09-28-2013, 15:34   #20 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,158
I got 1 Iphone 5 with the same error!!
Old 09-28-2013, 20:26   #21 (permalink)
Member: 1294044
Thanks Meter: 1,158
chang Cebel ues Orjnal 100% sol
Old 09-28-2013, 23:42   #22 (permalink)
Member: 1420702
Sonork: 100.1611226
Thanks Meter: 12
4013 hardware
this error is hardware i think baseband chip rehoot
Old 09-29-2013, 17:38   #23 (permalink)
cheyn's Avatar
Member: 646368
Thanks Meter: 52
100% correct..upgrading to ios7 error 4013 solution:
Use original usb cable.
P.S. After upgrade ios7 when using generic cable to charge it gives error:
"use original accessories compatibilty"MESSAGE.
Old 09-29-2013, 20:40   #24 (permalink)
Member: 2002240
Thanks Meter: 2
Yes, but if phone worked before upgrade there's a chance that's error on pc settings or software
Old 09-29-2013, 21:33   #25 (permalink)
Ifonefreak's Avatar
Member: 1961436
Sonork: 100.1612163
Thanks Meter: 30
I use original cables ... I still got 4013, i think 4013 is -1 on ios 7
Old 09-30-2013, 17:13   #26 (permalink)
Member: 2002240
Thanks Meter: 2
Bro have you checked the updater logs?
C:\Users\<UserName>\AppData\Roaming\Apple Computer\iTunes\iPhone Updater Logs
Here could be a lot of information about condition your phone.
Try to restore again and check the latest log. Paste it on pastebin.com etc. and we will try solve your issue
Old 09-30-2013, 17:16   #27 (permalink)
Member: 1892345
Thanks Meter: 11
i hv 3 iphone 5 with same problem...
[QUOTE=Ifonefreak;9759924]I got 3 Iphone 5 with the same error!![/QUOTE
Trying again true itunes restore....
Old 10-04-2013, 08:43   #28 (permalink)
GSMan's Avatar
Member: 1675
Thanks Meter: 44
Hardware solution
Hi
if you use last itunes and you have tested usb hosts etc the problem is at proximity sensor flex.
Remove the sensor and try again without connected then replace it
GabiRo
Old 10-04-2013, 09:37   #29 (permalink)
Member: 550428
Thanks Meter: 22
ipad 2 wifi, trying update to ios7.. but error 4013.
here is the log :
2013-10-04 16:34:07.546 [1128:6f8]: restore library built Aug 8 2013 at 02:24:58
2013-10-04 16:34:07.546 [1128:6f8]: iTunes: iTunes 11.1.0.126
2013-10-04 16:34:07.546 [1128:6f8]: iTunes: Software payload version: 11A501 (option key)
2013-10-04 16:34:07.546 [1128:6f8]: iTunes: Using MobileRestore state machine
[08:34:45.0515] Changing state from 'Idle' to 'Restoring'
[08:34:45.0515] requested restore behavior: Erase
[08:34:45.0515] requested variant: Erase
[08:34:45.0515] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is False
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 0803AE70 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0800E5B8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "KernelCache"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging0"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow1"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "AppleLogo"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "DeviceTree"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryCharging1"
[08:34:46.0578] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryPlugin"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 08020EE8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "iBoot"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryFull"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RecoveryMode"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "BatteryLow0"
[08:34:46.0593] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 0800E7C8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}
[08:34:46.0593] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled.
[08:34:46.0593] amai: AMAuthInstallDebugWriteObject: debug object written: C:\DOCUME~1\microtec\LOCALS~1\Temp\PerFB.tmp\amai\ debug\tss-request.plist
[08:34:46.0875] amai: tss_submit_job: HttpQueryInfo returned 200
[08:34:47.0156] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0)
[08:34:47.0156] amai: AMAuthInstallDebugWriteObject: debug object written: C:\DOCUME~1\microtec\LOCALS~1\Temp\PerFB.tmp\amai\ debug\tss-response.plist
[08:34:47.0171] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags"
[08:34:47.0187] iBoot build-version = iBoot-1072.61
[08:34:47.0187] iBoot build-style = RELEASE
[08:34:47.0187] requested restore behavior: Erase
[08:34:47.0187] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:47.0187] unable to open device_map.txt: No such file or directory
[08:34:47.0187] found device map entry for 0x00008940 0x00000004. boardConfig=k93ap platform=s5l8940x
[08:34:47.0187] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[08:34:47.0187] AMDeviceIoControl: GetOverlappedResult failed
[08:34:47.0187] AMDeviceIoControl: pipe stall
[08:34:47.0187] USBControlTransfer: error 31, usbd status c0000004
[08:34:47.0187] command device request for 'getenv radio-error' failed: 2008
[08:34:47.0187] radio-error not set
[08:34:47.0187] <Recovery Mode Device 042AF278>: production fused device
[08:34:47.0203] interface has 1 endpoints, file pipe = 1
[08:34:47.0203]
[08:34:47.0203] <Recovery Mode Device 042AF278>: operation 4 progress -1
[08:34:47.0234] bootstrapping restore with iBEC
[08:34:47.0234] requested restore behavior: Erase
[08:34:47.0234] <Recovery Mode Device 042AF278>: operation 31 progress -1
[08:34:48.0234] <Recovery Mode Device 042AF278>: Recovery mode succeeded
[08:34:48.0234] Finished Recovery Restore Phase: Successful
[08:34:48.0390] Recovery mode device disconnected
[08:34:48.0390] Device removed when in state Restoring, moving device to transition state
[08:34:48.0390] Changing state from 'Restoring' to 'Transitioning'
[08:34:48.0390] Creating timer to monitor transition
[08:34:56.0671] Recovery mode device connected
[08:34:56.0671] Transitioning device returned, continuing restore.
[08:34:56.0671] Canceling timer
[08:34:56.0671] Changing state from 'Transitioning' to 'Restoring'
[08:34:56.0671] requested restore behavior: Erase
[08:34:56.0671] requested variant: Erase
[08:34:56.0671] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: withApTicket is True
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 08065090 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 0802DCE8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 0801D818 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 0801D5A8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 07F58018 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 0802E138 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 08005FC0 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 08041FC0 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 07F312B8 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 07F46528 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0125] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 07A9F670 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 08066D68 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 0801D9E0 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 08040658 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 08063778 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 07F491E0 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 0801EF20 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 080334A0 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}"
[08:34:57.0140] amai: _AMAuthInstallBundleCreateServerRequestDictionary: using UniqueBuildID <CFData 0803A758 [01748078]>{length = 20, capacity = 20, bytes = 0x<<<<<<<<<<<<<<<<<<UDID>>>>>>>>>>>>>>>>>>}
[08:34:57.0140] amai: AMAuthInstallRequestSendSync: SSO function returned NULL, SSO disabled.
[08:34:57.0140] amai: AMAuthInstallDebugWriteObject: debug object written: C:\DOCUME~1\microtec\LOCALS~1\Temp\PerFB.tmp\amai\ debug\tss-request.plist
[08:34:57.0421] amai: tss_submit_job: HttpQueryInfo returned 200
[08:34:57.0703] amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0)
[08:34:57.0703] amai: AMAuthInstallDebugWriteObject: debug object written: C:\DOCUME~1\microtec\LOCALS~1\Temp\PerFB.tmp\amai\ debug\tss-response.plist
[08:34:57.0718] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBEC" has been previously personalized; skipping it
[08:34:57.0718] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "iBSS" has been previously personalized; skipping it
[08:34:57.0718] amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "LLB" has been previously personalized; skipping it
[08:34:57.0718] amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags"
[08:34:57.0718] iBoot build-version = iBoot-1940.1.75
[08:34:57.0718] iBoot build-style = RELEASE
[08:34:57.0718] requested restore behavior: Erase
[08:34:57.0718] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:57.0718] unable to open device_map.txt: No such file or directory
[08:34:57.0718] found device map entry for 0x00008940 0x00000004. boardConfig=k93ap platform=s5l8940x
[08:34:57.0718] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[08:34:57.0718] AMDeviceIoControl: GetOverlappedResult failed
[08:34:57.0718] AMDeviceIoControl: pipe stall
[08:34:57.0718] USBControlTransfer: error 31, usbd status c0000004
[08:34:57.0718] command device request for 'getenv radio-error' failed: 2008
[08:34:57.0734] radio-error not set
[08:34:57.0734] unable to open device_map.txt: No such file or directory
[08:34:57.0734] <Recovery Mode Device 07A61030>: production fused device
[08:34:57.0734] requested restore behavior: Erase
[08:34:57.0734] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:57.0734] interface has 1 endpoints, file pipe = 1
[08:34:57.0734]
[08:34:57.0734] <Recovery Mode Device 07A61030>: operation 4 progress -1
[08:34:57.0781] unable to open device_map.txt: No such file or directory
[08:34:57.0781] found device map entry for 0x00008940 0x00000004. boardConfig=k93ap platform=s5l8940x
[08:34:57.0781] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[08:34:57.0781] requested restore behavior: Erase
[08:34:57.0781] amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid and boardid only.
[08:34:57.0781] <Recovery Mode Device 07A61030>: operation 42 progress -1
[08:34:58.0828] <Recovery Mode Device 07A61030>: operation 5 progress -1
[08:34:59.0187] unable to open device_map.txt: No such file or directory
[08:34:59.0187] found device map entry for 0x00008940 0x00000004. boardConfig=k93ap platform=s5l8940x
[08:34:59.0187] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[08:34:59.0187] AMDeviceIoControl: GetOverlappedResult failed
[08:34:59.0187] AMDeviceIoControl: pipe stall
[08:34:59.0203] USBControlTransfer: error 31, usbd status c0000004
[08:34:59.0203] command device request for 'getenv ramdisk-delay' failed: 2008
[08:35:00.0875] <Recovery Mode Device 07A61030>: operation 6 progress -1
[08:35:01.0890] <Recovery Mode Device 07A61030>: operation 7 progress -1
[08:35:02.0234] <Recovery Mode Device 07A61030>: operation 8 progress -1
[08:35:02.0234] unable to open device_map.txt: No such file or directory
[08:35:02.0234] found device map entry for 0x00008940 0x00000004. boardConfig=k93ap platform=s5l8940x
[08:35:02.0234] _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options
[08:35:02.0234] <Recovery Mode Device 07A61030>: operation 9 progress -1
[08:35:02.0234] <Recovery Mode Device 07A61030>: Recovery mode succeeded
[08:35:02.0250] Finished Recovery Restore Phase: Successful
[08:35:03.0750] Recovery mode device disconnected
[08:35:03.0750] Device removed when in state Restoring, moving device to transition state
[08:35:03.0750] Changing state from 'Restoring' to 'Transitioning'
[08:35:03.0750] Creating timer to monitor transition
[08:35:18.0609] Restore completed, status:4013
[08:35:18.0609] Failure Description:
[08:35:18.0609] Depth:0 Error:Unexpected device state 'Recovery' expected 'RestoreOS'
how to solve?
Old 10-04-2013, 09:58   #30 (permalink)
rrvius's Avatar
Member: 1821491
Sonork: Never give up
Thanks Meter: 31
yday i sloved this error 4013 in my i5 i formate c program i dawnload itunes newly also download new cfw i restore its done with out any error!! now phone working very well try this hope ur prob ll b slove best of luck (just click thanks button if is sloved ur prob)
Page generated in 0.44487 seconds with 7 queries
