08-13-2015, 22:23 | #1 (permalink) |
Insane Poster Join Date: Jul 2012
Member: 1789946 Status: Offline Thanks Meter: 6 | error after remove resistor r1204 on ipad 4 a1460 Please help,Please help... [NAND] _FindFlashMediaAndKeepout:601 physical nand block offset 1 [NAND] start:356 this 0x9e0d3400 PROVIDER=0x9cb74c00 flashMedia=0x9cb74c00 [NAND] WMR_Start:149 Apple PPN NAND Driver, Read/Write [NAND] WMR_Start:174 FIL_Init [OK] [NAND] WMR_Open:371 VFL_Open [OK] [NAND] s_cxt_boot:88 sftl:error, unclean shutdown; adopted 18951 spans [NAND] WMR_Open:420 FTL_Open [OK] [NAND] _publishServices:642 FTL capabilites: 0x00000001 [NAND] _ppnvflGetStruct:3469 Checking borrowed blocks - count: 25 max_count: 25 [NAND] _fetchBorrowedList:881 number of borrowed blocks: 16 |
10-14-2015, 10:38 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote: i have solution if you face still issue contact with me |
10-16-2015, 17:30 | #6 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Brno, Czech Republic Age: 44
Member: 67574 Status: Offline Thanks Meter: 8 | I have same issue, removed R1204 in A1460 CDMA and try to restore with wifi firmware and get sometime this error, sometime error 4014 sometime waiting for ipad |
11-19-2015, 09:52 | #7 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2234263 Status: Offline Thanks Meter: 14 | Ok thus happened to me when I bypassed a1475 (iPad Air) and when I bypassed a1459 (iPad 4) it would download the proper Ipswich and extract it in iTunes fine and it would start the restore process but alert at the same point would lose the connection to the iPad while restoring. This was with fully rebuilt iPad. Would always give same restore error 4014. The only way I was able to get it to properly restore was by disconnecting the battery and using a dc power supply on the iPad while restoring. And it worked perfectly each time I just watched the restore log files and when it said restore success finally I took it off the dc power supply and connected the iPad battery like normal and I was able to power it on with the power button and the setup process began. |
