Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-06-2019, 17:19   #1 (permalink)
bifout's Avatar
Member: 145088
Thanks Meter: 12
Failed to change SN of an iPad Air
Hello everyone,
I am confused regarding this iPad Air that is driving me crazy!
Ok, hereis the sketch:
- i changed the old SN (SN, WIFI, BT) into the new one, and tried to activate!
while doing this i am supposed to get the iPad unlocked but unfortunatlly the iCloud lock remains,
- Checked the SN, i found that the original one (locked) remains it didn't change,
- I put the MB into the Naviplus and read the data, the naviplus gave me that the ipad is using the new SN!!!
puting the ipad into recovery, then reading the SN, the original one is displaying
And this is confusing
- i restored the ipad manytimes from recovery, from DFU,
Conclusion
The reading : From the PC the OLD SN
: From the Naviplus THE NEW unlocked SN
Note : I am using Naviplus version 1.1308 and IPAD4/5 adapter. Tried with an iPad 4 everything goes well!
Did anyone experienced the same thing? Did Apple patched the new OS or changed the location of the SN? i am using the 12.1.1
Thanks for your help
The Following User Says Thank You to bifout For This Useful Post:
Old 01-09-2019, 12:29   #2 (permalink)
Member: 18767
Thanks Meter: 41
U must erase nand and write new boot with new sn
Sent from my SM-N920C using Tapatalk
The Following User Says Thank You to mafioso3 For This Useful Post:
Old 01-09-2019, 14:38   #3 (permalink)
Member: 2277735
Thanks Meter: 157
Originally Posted by bifout View Post
Hello everyone,
Conclusion
It happens, check navi is up to date, write the serial multiple times, I had same problem on one board, rest wrote with out issue, no need to erase nand!
Old 01-13-2019, 03:39   #4 (permalink)
Member: 2691507
Thanks Meter: 98
Hello everyone,
Conclusion
Navi not writting the information in the right "places" check if you are using the laters version.
Old 01-13-2019, 16:34   #5 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 797
maybe can to be useful : yesterday i've unlock ipad air model A1475 so cellular version .
my solution for this without nand remove : i removed resistor as as was done in previous versions of ios , purchase new serial and write with easy adapter 56 , put ipad in dfu and restore using itunes ,done.
Relock immediately with my icloud account to make sure the new serial can not be placed again
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 01-24-2019, 20:15   #6 (permalink)
bobo bokota's Avatar
Member: 2148606
Thanks Meter: 185
I also know this error but in Naviplus do not support some numbers of nand but try with IP box v2th to write the new serial number
Envoyé de mon Sunny3 en utilisant Tapatalk
Old 01-25-2019, 06:45   #7 (permalink)
Member: 861495
Thanks Meter: 38
i have jc pro 1000s and i have the adapter I cant change serial on two ipad air i have done everything and it will not change i dont know how to make it write serial only happended with these airs
Old 01-25-2019, 16:03   #8 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,587
yes but after that you can use it with wifi only right ?
and if you put back resistor it relock to old icloud or with new icloud ?
Old 01-27-2019, 04:35   #9 (permalink)
MA7MOD_GSM's Avatar
Member: 1298774
Sonork: 100.1584126
Thanks Meter: 92
Sure if back resistore ipad need restore and not activate until you back original SN, but in reasons apple can lock Nand to rewrite some blocks address in iphone and ipad after update ios, apple can do that and maybe your nand number not support
Page generated in 0.27106 seconds with 7 queries
