11-24-2016, 12:00 | #62 (permalink) | |
Freak Poster Join Date: Dec 2004 Age: 41
Member: 97043 Status: Offline Thanks Meter: 29 | Quote:
The Following User Says Thank You to segun For This Useful Post: |
11-24-2016, 12:08 | #64 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Quote:
And depends on which components you have to clean and what components are around. I personally go for 220 degrees and air 30/40 on 100 (on ayoue system) Then gently and slowly scrap the glue with the tip of a cutter. Better to start, then stop and clean, and then start again. You need time and especially patience. If you getting nervous better to have a break and continue after some time. MANDATORY is the buses of a microscope Sent from my SM-G925F using Tapatalk | |
The Following User Says Thank You to excessive For This Useful Post: |
11-24-2016, 12:10 | #65 (permalink) | |
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | [QUOTE=Nipsta;11944758] Quote:
04-07-2017, 09:34 | #68 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2704090 Status: Offline Thanks Meter: 1 | Hi guys! First post here. What stencils do you use for reballing? I have a some stencils from China and they deform when trying to reball something small (like baseband from iphone 6), and the paste goes under it, shorting everything. This is happening even if I do press the stencil down on the chip. Are the 0.2mm balls available for sale, a better solution instead of the solder paste? |
04-07-2017, 10:50 | #69 (permalink) | |
Freak Poster Join Date: Dec 2013
Member: 2080974 Status: Offline Thanks Meter: 12 | Quote:
05-29-2017, 12:26 | #73 (permalink) |
Freak Poster Join Date: Mar 2012 Location: in you are heart Age: 37
Member: 1733871 Status: Offline Sonork: 100.1627020 Thanks Meter: 28 | hello. hardware experts can u advice me the problem we change both audio ic but still condion same plz ckeck the link no sound http://forum.gsmhosting.com/vbb/f631...sound-2228438/ |
