06-22-2017, 23:58 | #181 (permalink) |
Junior Member Join Date: Jun 2007
Member: 532148 Status: Offline Thanks Meter: 0 | I soldered an iphone 5 nand from a dead board i had here and iphone gets to dfu and then i get 4014 error. i tried puttint the old nand back but i think i might have killed it while trying to make sure that i remove the chip without damaging the board because it does not start at all with the old one, not even in DFU, i can hear a weird sound like a clicking hdd coming from the nand chip. So my question is, did i kill the board, or both of my nand chips are bad? |
06-23-2017, 00:48 | #183 (permalink) |
Member: 532148 Status: Offline Thanks Meter: 0 | i did not reprogram it. as i said i am new to this, i normally do gaming console repairs. from what i understood it should have worked without programming. if i would have had a way to program, i would have programmed the original nand since it was 32 gb not 16 like the one from iphone 5 |
06-23-2017, 01:23 | #184 (permalink) |
Member: 532148 Status: Offline Thanks Meter: 0 | i want to check the nand voltages but i can not find any 3V also, all big caps seem to have 1.8V at one of the ends except one of them. so i dont know if its supposed to be like this because i can not find any references to compare to. around the nand there are 6 big caps. i get voltages on 5 of them (1.8), so maybe this is the problem? |
06-23-2017, 02:18 | #185 (permalink) |
Member: 532148 Status: Offline Thanks Meter: 0 | i do not see an edit function here, so sorry for the triple post. so i have reattached the iphone 5 Nand again and also reflowed the smd's that i previously moved. i have made a picture as well, I have 1.8V at all the big capacitors red circled ends now. so i think the problem is in the nand. what do you guys say? should i order a reprogrammed one from china? i can not find any in europe... see picture here: h t t p s :/ / ibb. co/ nwVUA5 (remove spaces) |
06-23-2017, 08:35 | #186 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
06-23-2017, 22:53 | #187 (permalink) | |
Crazy Poster Join Date: Mar 2017
Member: 2697189 Status: Offline Thanks Meter: 37 | Quote:
06-23-2017, 23:04 | #188 (permalink) | |
Failing to preheat can damage pad links underneath pab due to thermal shock. At the very least high air flow at 150 for a few minutes then upto 350 to lift nand at moderate flow. this also greatly reduces the epoxy strength which drops to nothing at 230. A nand costs peanuts, the board protection is more important and the nand is better made than the pcb lol | |
06-25-2017, 05:32 | #189 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
I'll get more readings and post. | |
06-25-2017, 09:01 | #190 (permalink) |
Member: 532148 Status: Offline Thanks Meter: 0 | i know preheating is very important as i do professional reballs on daily basis, but on much bigger hardware. what i dont understand now is if the board is damaged or i need a new nand. as far as i can tell, the board goes to DFU successfully, but i need to reball the touch ic as well since 2 solder balls slided out from under it. I tried removing nands from 2 other dead devices before just as a practice, and it all went ok and much easier than this ipad. with this one it seemed like it just did not want to move so i did apply temperature for quite a while, but did not went above 320, then went to 400 for a very short time when i was also able to remove the nand chip. the pads look good and i tested some of them that i could trace and they do have continuity. maybe if there would be a diagram to test the others out it would be great. |
06-26-2017, 18:28 | #192 (permalink) | |
This is iTunes log from before, battery 4.0 and usb, log 31k, stops on second DFU loop. [23:25:50.0456] WinDFU::UploadData: ZLP [23:25:50.0472] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [23:25:50.0472] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [23:25:50.0472] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [23:25:50.0472] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [23:25:53.0477] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [23:25:53.0477] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [23:25:53.0477] WinDFU::ResetDevice: resetting... [23:25:53.0530] WinDFU::FinalizeDfuUpdate: success [23:25:53.0530] <DFU Device 000002253144BDF0>: DFU succeeded [23:25:53.0530] Finished DFU Restore Phase: Successful [23:25:53.0530] DFU mode device disconnected [23:25:53.0530] Device removed when in state Restoring, moving device to transition state [23:25:53.0530] Changing state from 'Restoring' to 'Transitioning' [23:25:53.0530] Creating timer to monitor transition [23:25:53.0530] Creating a timer for 10 minutes [23:29:00.0635] DFU mode device connected [23:29:00.0635] Transitioning device returned, continuing restore. [23:29:00.0635] Canceling timer [23:29:00.0635] Changing state from 'Transitioning' to 'Restoring' [23:29:00.0635] AppleDevice::GetDeviceID: failed for iBoot [23:29:00.0636] AppleDevice::GetDeviceID: failed for iBoot [23:29:00.0636] requested restore behavior: Erase This is now with power 4.2 & usb, it will not switch to DFU/Restore - log only 18k it stops on the first DFU loop [02:43:15.0819] WinDFU::UploadData: ZLP [02:43:15.0821] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 [02:43:15.0821] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC [02:43:15.0821] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 [02:43:15.0821] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 [02:43:18.0842] WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 [02:43:18.0842] WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET [02:43:18.0842] WinDFU::ResetDevice: resetting... [02:43:19.0028] WinDFU::FinalizeDfuUpdate: success [02:43:19.0028] <DFU Device 000002C1B265C170>: DFU succeeded [02:43:19.0028] Finished DFU Restore Phase: Successful In all the restores I have done the DFU loop is two times, on the second it will switch to recovery. | |
