11-05-2016, 21:32 | #136 (permalink) | |
Major Poster Join Date: Jul 2016
Member: 2602250 Status: Offline Thanks Meter: 11 | Quote:
11-25-2016, 02:25 | #139 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2652213 Status: Offline Thanks Meter: 0 | hello everybody !! amazing topic !! my ipad 3 has two sockets with one nand... if i place the new one nand in the other socket is that a problem ? because the old socket is not in very good condition :P but without short circuit .. the old was near to the cpu and i want solder the new away from the cpu. its this ok ? |
11-27-2016, 20:29 | #140 (permalink) | |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | Quote:
if only one nand present, you must desolder old nand and put the new one in the socket of the old one | |
11-28-2016, 09:35 | #142 (permalink) | |
- with a thin blade scrape the glue on all sides around the nand before heating to prevent desoldering nearby components - when heating, protect nearby components with kapton tape or coins - when heating, pe patient and try to insert the blade between nand and board without force; when the solder is melted the blade will enter easily | |
The Following 2 Users Say Thank You to mcmihai003 For This Useful Post: |
11-28-2016, 09:41 | #143 (permalink) | |
The Following User Says Thank You to mcmihai003 For This Useful Post: |
12-02-2016, 12:37 | #145 (permalink) |
Member: 1675922 Status: Offline Thanks Meter: 61 | as long as you have all pads, it's ok... so, i would use solder wick to clean pads and all traces of old solder then use some soldermask for masking the traces and ground. also, it's possible that after new nand reball it will not fit perfectly. in this case you may need to scrape the old glue from the board (scrape it with a small knife and hotgun or with a thin tip of iron set at about 250-300 degrees) |
12-05-2016, 14:20 | #146 (permalink) |
Member: 1675922 Status: Offline Thanks Meter: 61 | just replaced nand on a ipad2 a1395; restore seems to finish successfully but after the restore is finished and ipad should restart it shuts down. after push for few seconds on both power & home buttons the message "connect to itunes" appear and ask for restore...and so on... sometimes, i am able to boot successfully and everything seems to be ok, but after a while is shuts down and ask for restore again... any ideas? thx! |
12-07-2016, 04:04 | #148 (permalink) | |
Member: 2652213 Status: Offline Thanks Meter: 0 | Quote:
12-09-2016, 04:25 | #149 (permalink) |
Member: 2652213 Status: Offline Thanks Meter: 0 | Which this the right direction of nand on iPad 3 wifi ?? I have resoldering 10 times and every time stuck on the Apple logo with the empty loading bar and on PC waiting for iPad.. Any ideas ? |
12-09-2016, 04:25 | #150 (permalink) |
