05-17-2016, 18:09 | #33 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 315344 Status: Offline Thanks Meter: 5 | Hello Forum, I have IPAD 2 A1395 EMC2415 with 64GB (32 x 2) NAND Flash of Hynix. I have another 16GB TOSHIBA IPAD 2 NAND Flash. I have removed both nand flash from my 64 GB ipad2 and replaced with 16GB. and the iTune is stuck on Waiting for IPAD error and on the ipad2 there is Apple Logo with Progress bar. Could you please tell me where is the problem what should i do ? Regards, Shan Last edited by sakaz; 05-17-2016 at 18:10. Reason: Typographical error EMC 2415 instead of 1415 |
05-18-2016, 08:26 | #34 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
And you didnt made any damage to the board? If i have this error is need to redo (reball) or reheat the NAND again. | |
05-26-2016, 06:40 | #35 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | please if you have any details about bga nand desoldering on ipad 2: what temp is set on the heatgun? how large is the nozzle? how long it should take before the solder is melting and nand can be removed? thx! |
05-31-2016, 11:49 | #36 (permalink) |
Member: 1675922 Status: Offline Thanks Meter: 61 | just received 16gb nand for ipad2 old model but some pads are missing (see link below: https://onedrive.live.com/redir?resi...nt=photo%2cjpg do you know if there are not connected pads or the chip is defective? thx |
06-03-2016, 16:00 | #38 (permalink) |
No Life Poster Join Date: Mar 2012 Location: Amsterdam, Netherlands
Member: 1732818 Status: Offline Thanks Meter: 532 | Yes It works I have taken the nand from no icloud lock ipad 4 and have placed it in an ipad 4 that was icloud locked. Now the icloud activation lock is gone. Thank you! |
The Following User Says Thank You to HDccam For This Useful Post: |
06-04-2016, 22:01 | #39 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1327373 Status: Offline Thanks Meter: 0 | Hi All! I'm searching for an ME7** board, but I cant find in my region. (ME128 / MD*** and others of course available). So the serial rewrite will not work if I use a random board, and solder the iPad test points the place where the iPhone nand was??? I wont pay hundred bucks for a nand writer. Is there any other nand write technique, instead the nand replace? Thanks for the answer. |
06-06-2016, 13:21 | #40 (permalink) |
Member: 1668980 Status: Offline Thanks Meter: 35 | Hi the iphone 3,2 8GB md128 board works fine for me can only write 32bit iC eg: ipad 2 2nd gen, ipad 3, ipad 4 ipad mini 1st gen on another matter does anyone know where the baseband is stored in all the ipad 3G ? |
The Following User Says Thank You to calais250 For This Useful Post: |
06-06-2016, 15:01 | #42 (permalink) |
Member: 1668980 Status: Offline Thanks Meter: 35 | yes, i thought i was the only one with this problem, when set to read it is empty must be software related, but writing is fine, so i write serial ,model number no problem so far |
06-07-2016, 14:44 | #44 (permalink) |
Member: 1668980 Status: Offline Thanks Meter: 35 | No i only see blank output but I have seen that error before, my soldering was so bad i missed a few pins and the only way was to check contiuty on all the pins and now I have blank result when i read but writing is fine, |
