Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-16-2018, 19:42   #1 (permalink)
Member: 1810243
Help please iphone 8plus layers
I drowned my iphone 8 plus, and it turned out that the main closure occurred in the area of the capacitor C7608_W and the coil FL3995, as a result of which several layers (1-2-3) of the board were burned and, apparently, in a short one. Please, if anyone has such an opportunity, share please the layers
Thank you
Old 09-14-2021, 12:14   #2 (permalink)
Member: 2872060
Hi
Did you finally do the repair ?
I have the same PB on a motherboard
How did you found out that deep connection layer were touched ?
I am ordering parts for it but the FL3995 is hard to find
FL3995 = 10 ohm 750 mA 01005
C7606_W = 0.01UF 6.3V X5R 10% 01005
Old 09-14-2021, 13:14   #3 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 253
use a short killer to burn it to remove the short enject voltage in vcc main not in batery terminal this connection is just in the surface..maybe if its burn until 5th layer you will not have back camera..and mostly you need to reball wifi and make new connection of vcc main to wifi to make wifi work
Old 09-16-2021, 06:01   #4 (permalink)
Member: 2583697
Sonork: 100.1677424
Thanks Meter: 21
Thank you
Check this link
Old 09-16-2021, 08:59   #5 (permalink)
Member: 2872060
Hi
Thank you for your reply, the short has already been removed.
I do not have a short killer, it's kind of scarry for me. I have seen video, that's all.
I also have 2 caps on an iphone 8 Intel called C147 and C148 but cannot find their values and can only see them on the Bitmap but not on the schematics.
Unless there is an error on my Bitmap
If someone could check for me it would be great
Page generated in 0.11779 seconds with 8 queries
