11-23-2014, 21:55 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: In GSM World Age: 45
Member: 6418 Status: Offline Thanks Meter: 64 | How I Bypass iCloud Ipad2 A1395 Thanks In Advance |
The Following User Says Thank You to tanim For This Useful Post: |
10-31-2015, 20:01 | #6 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2142442 Status: Offline Thanks Meter: 53 | Don't play with the resistors its wifi iPad and it's locked by the serial number not with the imei . So you have to change the serial and that is in nand memory. You have to replace it from another one unlocked or with nand flash memory tool change the serial. If the iPad is GSM/3G you simply remove the resistor so you can do it wifi only with no imei. |
The Following 3 Users Say Thank You to qwertybasse For This Useful Post: |
11-29-2016, 22:26 | #9 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | watch this video and it can give you some ideas no need to desolder Nand ic but you need ipad 2 2nd generation and it can be used for ipad 3, ipad 4 all wifi https://www.youtube.com/watch?v=b-7wA4ayRrI |
12-04-2016, 15:23 | #10 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Jamaica
Member: 1710758 Status: Offline Thanks Meter: 55 | This method will probably show u the apple id info i tried on a ipad mini 3 wifi version but it facetime came up empty. Give it a try and tell me if it reveals the apple id info https://www.youtube.com/watch?v=dSPBo2m-8yE |
12-25-2023, 00:18 | #13 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | I do it just by MagicoDIAG if it is WIFI model, anyway. But for the GSM model need remove resistor and flash with the flash file of the WIFI iPad model and nothing else as it will get activated immediately after that.... The GSM model can also be bypassed with Arduino and some old iPad models without Arduino, just a tool called Sliver 6.2 etcetc |
