Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides. |
| | #46 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2012 Location: Italy
Member: 1741592 Status: Offline Thanks: 42
| i helped a lot too for free expecially on xbox 360 that i'm an expert. I helped also other people on finding solution on consoles xbox and ps3, and building the right profile for reattach. Tell them all my secrets to have a perfect reattach and a long lasting soldering... i like when they thank me, but sometimes some people when have success, they simply go away without any thanks, showing up again when next problem appears...i don't want money, but a thank is always great |
| | #47 (permalink) | |
| Moderator ![]() Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 27
Member: 1017374 Status: Offline Thanks: 68
| Quote:
| The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
| | #48 (permalink) |
| i still have the 2 symptoms: 1) LCD bright up itself (i realize that the problem is or dock connector or more probably home button...but at the moment HOME BUTTON is disconnected, the gold clip could be the problem because sometimes it says VOICE CONTROL and it appear only when keep pushing HOME 2) Battery always charging, never reach 100%, still miss the very last thick! Really can't figure it out what it cause it... |
| | #49 (permalink) |
| on the rear of motherboard, just near the soldering point of speaker, there is a quite big component all browned. I thinked it was flux or something else, but scraping it doesn't clean it. So i measured its resistance and is infinity. So i though that it was a resistor, and i've shorted it. For trying i've also put a screw in one of the hole of dock connector to fix it strongly to the back cover, then solder back the battery, ready for another try. Now the LCD issue seems to be solved, but still remains problem number 2. So 1st problem is due to a bad connector (seems strange, i've resoldered each pin manually with flux+iron) or that burnt resistor (maybe caused by a previous time when filter charging burned) |
| | #50 (permalink) |
| | #51 (permalink) |
| mmm no way...the 1st problem reappear when i plug it back to the PC...it depends on lucky...unplugging the usb cable select the issue...sometimes appear sometimes now...if i plug/unplug a couple of times and i see the issue is solved, is ok! never see the issue anymore...but the issue could appear as soon as i connect it to the PC, and need to plug/unplug a couple of times to take it away...so, could be connector or software problem i think, but can't realize the 2nd problem. when i plug/unplug multiple times, sometimes the very last thick of battery is completed and the icon is CHARGED. The plug/unplug thing is the cause of all my problem...maybe also the 2nd problem is due to dock connector! I've already ordered a new one...will see what happens |
| | #52 (permalink) |
| | #53 (permalink) | |
| Quote:
![]() That you jumped i think is inductor not resistor show picture. | |
| | #54 (permalink) |
| here you are: ![]() but if i remove that varistor, home button won't work anymore? :S However, brushing with IPA i've lost the superior half of the gold clip home button, the one is your photo, just over the varictor. How to fix that? :S |
| | #55 (permalink) |
| Oh my gosh this inductor is for video buffer ic no jumper,are you sure home button not work without varistor?Because it is ESD component not important. Solder an goldplated pin from other phone in place of removed. Also chk if you not removed varistor with track if so make a jumper from gold dot of home button to near resistor. |
| | #56 (permalink) |
| nono mate i've still not tried...i was only asking...tomorrow gotta try it thanks ![]() i will remove varistor sorry i didn't understand your last phrases.please could you explain simply my friend?or maybe a schematic or photo! Do you have ipod 4 schematics? Really can't find them ![]() and i really don't know where to take the gold clip, don't have another ipod 4 |
| | #57 (permalink) | |
| Quote:
| | #58 (permalink) | |
| Quote:
the jumper i showed you in the photo i must done it because resistance was infinity...so resistor or inductor, it was visibly burnt. Also usb filter was burnt, and as you tell in your solution i've jumpered it and also the USB mosfet. i've removed also your varistor, nothing changed. If i press with the finger the gold clip (or what remains of it,as the top part is gone as i said you ) and home button working properly.But problem remains...if i don't push anything, screen will light up itself...sorry my friend, it didn't work other probably solutions?tomorrow will arrive the new socket...will see if it solve the problem | |
| | #59 (permalink) | |
| Quote:
I can tell you if inductor was burn then video buffer ic could be burn and it could influence the lcd to light up. | |
| | #60 (permalink) | |
| Quote:
that inductor had visible burning damage...how to check if the IC is visible burnt or not? Theorically if i desolder it, it should work anyway without it, but can't watch videos is right? I could give a try, only to see if LCD lights up itself! However, sometimes when i plug usb cable it say CHARGE NOT SUPPORTED...i have to unplug and replug it again, sometimes 2 or 3 times.. Last edited by seve91; 07-17-2012 at 11:13. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 06-27-2012 11:00 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| £2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 09:52 |
| I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
| HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 07-16-1999 00:44 |
