11-29-2009, 16:09 | #76 (permalink) | |
Junior Member Join Date: Nov 2009
Member: 1172227 Status: Offline Thanks Meter: 6 | Quote:
i'm a poor frenchie guy with a 3g iphone water-dammaged (be indulgent with my english...). So i replace the battery (the old was fully corroded), and like lots of tuto on web i put my motherboard/LCD/case into rice recipient for a night. The next day, i replace the battery and the phone restart!! But no charging/communicating with the pc. However, it's say to plug with itunes because the phone is unable to find is IMEI/ICCD. By entering the DFU mode, the usb is recognise, and itunes let me chose to restaure the phone, i answer ok. Then white screen, and error 23. But the problem is the new battery is now discharged, and phone is in black screen!! unable to restore and recharge! The part u specified is protected by a metallic case, so i can't see the components under. You said you link 2 points betwen us, but there is 4 points! u link it horizontally or vertically? (see picture inside my post). OR I think the phone is not dead, and the restore mode require charging under usb to continue, so mine can't! Please send me answers to put him back to life! (tanks for the greats and patients readers!) | |
The Following 6 Users Say Thank You to mathieurob For This Useful Post: |
11-30-2009, 14:01 | #79 (permalink) |
Member: 1172227 Status: Offline Thanks Meter: 6 | ok merci beaucoup !! Je suppose que l'oxydation brule les pistes concernées, toute façon il part en SAV apple aujourd'hui, si il revient non réparé/remplacé je tenterais l'astuce! Par contre on est obligé de détruire la cage métallique qui entoure les composants pour y accéder je suppose? Par contre me concernant erreur 23 lors de la restauration via itunes, je pense que la flash modchip est endommagée. Verdict mercredi! Merci encore l'ami, tu sauves un paquet de personnes |
11-30-2009, 21:07 | #80 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | sir iphone 3g speaker not working sir , i change that speaker sometimes its working for 5 to 7 calls and then its working sir what complaint it will be . it should change the speaker stip too sir plz help me what to do sir |
12-06-2009, 21:11 | #83 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Romania
Member: 467437 Status: Offline Thanks Meter: 31 | iphone 3G camera problem and no network or wifi hello guys, iphone 3G in my hands, it was 2.1 fw version, when u turn the camera on, no image, no network and no wifi, i disassembled the phone and turned it on holding all the components in hand, observed that a lot of heat was generated from the multi pin capacitors on the other side of the camera connector, i took out the camera and the heat disapeard, so i guess that there is something shorted in the camera, i don't have yet another camera to try with but, there is still no wifi signal and network .... NO SERVICE, updated the phone to 3.1.2, same problem no WIFI ... and no network, one more problem, if the iphone is not unlocked, but still activated, would i be able to connect to a wifi network ? any way .. what can i do to fix this ? i think that the phone was a little watter damaged. Does anyone can also help me with a picture from the NAND flash round and round it, not from upper side, i see some interrupted pins between the flash and the board. (pic showing what ware the components that ware burning when camera connected ) 10x to everyone ... |
The Following 5 Users Say Thank You to fricosu007 For This Useful Post: |
12-09-2009, 01:44 | #85 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1179430 Status: Offline Thanks Meter: 8 | Missing Antenna Capacitor Hello guys, firts of all, thanx for the hard work! Great diagrams and big help!! My problem is that I get a 3g iphone with no signal, and when I open it the problems seems to be that there is no link between the pcb and the main antenna, the pcb is broken on the botom that conects to the main antenna, so I had no idea wich cap were there... As everithing else work fine, I wonder if someone could tell me wich capacitor is soldered on the pcb, on the track that conects to the main antenna (specs as size doesn´t matters). I donot know why I can´t atach anything... but it is the capacitor next to where the main antenna conects... Also, I´m right to asume that the other part of this edge is for conecting ground and the aluminium frame? Thanx in advance! Chad |
12-10-2009, 03:37 | #87 (permalink) |
Member: 1179430 Status: Offline Thanks Meter: 8 | Here is the pic of what I need (I don´t know why I still can´t get attachements...) please someone interested in helping me I would really appreciate! everything upside the fracture line is missing (I´m not so rude, I get the iphone without signal for repair and thats seems to be the fault, some kind of neandertalian technician trying to disasemble it without internet and with a hammer only)... I get a way to solder some wire to the antena line, but I miss the capacitor and also the metal that connects to the frame. So what I need is a diagram of the antena and the conector to the frame (if it doesn´t go directly). Thanks in advance! Chad PW: I have allready repaired the power button flex, so you can see that I´m not interested of replacing anything hehe |
The Following 2 Users Say Thank You to chad720 For This Useful Post: |
12-10-2009, 21:24 | #88 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Cracow
Member: 739941 Status: Offline Thanks Meter: 111 | Remove the slot of external antenna, and sticker , take the wire form pads (where you connect antenna) to the place under sticker |
The Following 9 Users Say Thank You to artusb For This Useful Post: |
12-11-2009, 00:20 | #90 (permalink) | |
Member: 1179430 Status: Offline Thanks Meter: 8 | Quote:
Do you think is there a diference wiring under the sticker or close to the fracture line? also, the back of the "scare to remove", behind the sticker, has a circle wich I assume has antenna signal. And please don´t forget that I doesn´t have the pad for the antena, everything that goes up the fracture line is missing... that´s why I would appreciate if someone could tell me the values of the missing capacitor. Thanks again! | |
iPhone 3G S Diagram Here | delower10 | iPhone, iPad, iPod Hardware Repair | 11 | 12-27-2010 14:57 |
IPhone 3g broken motherboard no service | Farntet | iPhone 4 / iPhone 4S | 4 | 11-25-2010 11:51 |
iphone 3G MotherBoard Diagram------By {{{Rasel--Wingstel--Bangladesh}}} | Wingstel | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-27-2010 12:26 |
iPhone 3G S Motherboard Diagram by parts | Zulea II | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-23-2009 08:03 |
