06-09-2018, 21:59 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | ICLOUD remove IPADS 3G TO WIFI - NOT Possible anymore??? I have A1490 ipad mini 2 3G CELLULAR AND WIFI MODEL I made it wifi model by removing resistors FOR REMOVING ICLOUD I bOUGHT bluetooth wifi and serial and wrote on NAND I verified all SERIAL WIFI BLUETOOTH IN 3UTOOLS and all is OK Ipad restored good now ipad is not activating and giving error I BOUGHT WIFI SERIAL BLUETOOTH 2 TIMES FROM 2 SOURCES STILL NOT ACTIVATION why? APPLE IPAD 3G CELLULAR NOT POSSIBLE REMOVE ICLOUD ANYMORE?? |
06-10-2018, 02:20 | #2 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Algeria
Member: 2287326 Status: Offline Thanks Meter: 54 | I rely on both of these free services, check your serial number if it’s really for iPad mini 2 model because there’s some incompatibility which I don’t know about. Last time I bought and tried many SN for iPad mini 4, none of them seemed to work until I used mini 1’s SN. Hope this could help you, good luck! http://iunlocker.net/check_imei.php https://ifreeicloud.co.uk/free-check |
The Following User Says Thank You to Zaki Bouzidson For This Useful Post: |
06-10-2018, 03:17 | #3 (permalink) | |
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | Quote:
For information - All serials I used before are clean and are from IPAD MINI2 WIFI ONLY | |
06-10-2018, 03:26 | #4 (permalink) | |
I have also used SERIAL WIFI AND BT FROM DONOR IPAD MINI2 board and still not activating Maybe something with ios 11.4? Question for you - When was Last time you removed ICLOUD on ipad mini 2 cellular or any other model? Thank you | |
06-11-2018, 22:01 | #6 (permalink) | |
I will try changing color, area etc - And, when was last you removed ipad cloud successfully on ios 11.4 (not ipad mini1) | |
06-14-2018, 08:59 | #9 (permalink) | |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | Quote:
I have a navi 3000s so know what im talking about so dont undermine me by coming out with a silly reply when all i was doing was trying to help! | |
06-16-2018, 10:11 | #10 (permalink) |
Member: 2287326 Status: Offline Thanks Meter: 54 | If nothing is wrong with the latest iOS update then it is time for some measurements! Make sure you did the logic board conversion the right way, maybe something’s not good with a resistor even when it accepts the Wi-Fi model firmware.. you never know!! The link for the official method by pasha4ur is here |
06-16-2018, 16:27 | #12 (permalink) | |
i did not mean in other way, sometimes I make typing mistakes too. i have IPox latest version i will try changing - Area - color - Model i have already tried changing before. I appreciate time you are taking to help me out | |
The Following User Says Thank You to christina_ For This Useful Post: |
