Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-15-2012, 00:41   #1 (permalink)
Member: 1772119
I'm in way over my head with an iPad 2 3G
I've done a lot of repairs on different iPhones and laptops before, and I have never screwed up like this. This may be a weird place to post this, but the forum showed up in a Google search, and seems like as good a place as any.
FYI, iPad 2 3G, CDMA
The original problem was that the glass was cracked. I was removing the glass, and accidentally ripped the 3G antenna. No big deal, they are cheap, so I bought a new 3G antenna and went to replace it. I was drunk while replacing the 3G antenna and replacing the 3G antenna required lifting up the 3G Module. Naturally I completely ripped the 3G module from the motherboard
Picture - https://dl.dropbox.com/u/13042716/iPad.jpg
Additional Info - iPad 2 3G GSM & CDMA Teardown - iFixit
On this link, you can see that the CDMA chip (called WWAN there) The iFixIt page mentions this about the cable I ripped from the WWAN "These cables make the WWAN board not user-replaceable, as the cables securely (and permanently) attach the WWAN board to the logic board."
I don't really care for that answer.
I try to boot the iPad up, and it tells me to connect to iTunes. I connect to iTunes and iTunes says "iTunes could not connect to the iPad '[my mother]'s iPad' because it is locked with a passcode. You must enter your passcode on the iPad before it can be used with iTunes."
The iPad does not have a passcode box.
I reset the iPad, same story.
Also a while after restoring or turning on a box pops up that says
"Restore Needed
iPhone cannot make or receive calls. Restore From iTunes.
www.apple.com/support"
Yes, it says iPhone.
I taped down the connector that I ripped off and it should have been making a good connection, but it still showed that after a reset.
Suggestions?
Old 06-15-2012, 04:20   #2 (permalink)
Member: 1615254
What the iFixIt page said is probably quite true. Whether you want to hear it or not.
Unless you are exceptionally talented at electronic soldering, etc, this is probably way out of your control. You have damaged the board probably beyond repair.
If you can provide some better photos, maybe the genius types can offer a solution.
Old 06-30-2012, 03:02   #3 (permalink)
Member: 1778652
Unfortunately I am in this exact same boat but I went a step further and tried a restore. It fails with an error 1 (obviously because it is not seeing the WWAN board). I actually managed to cut all 3 antennas on this exact same model and replaced them, but not really knowing what I was doing I removed the board to get to the antenna connectors. If anyone has any suggestions it would be quite helpful, otherwise it will just be a 500$ coaster, So I am willing to try anything . Cheers!
Old 06-30-2012, 08:09   #4 (permalink)
Member: 1437600
it is a lesson for u not to fix it when u drunk, i think u screwed up gsm on logic board.
Old 06-30-2012, 09:49   #5 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
I think it can be fixed by making jumpers from board to board.
Old 09-14-2012, 03:19   #6 (permalink)
Member: 1376288
Sonork: phone21
Im also stuck with same problem , is there a solution for this ?
the why i removed is , I tried to replace the verizon gsm board with at&t gsm board to make it work with all carriers .
so please help me
Old 09-14-2012, 03:38   #7 (permalink)
noobfix's Avatar
Member: 1738165
it can be fixed. that message is there because you ar emissing the 3G board. just tape it back with z axis conductive tape. Assuming you did not dnamage any gold pad on either board and the tape cable itself is not ripped into pieces. in that case you also need the ribbon cable on top of the z axis tape. iPad 2 - CyberDocLLC.com Your Repair Solution for iPhone, iPod , iPad and Apple Prodcuts
Old 02-17-2013, 12:58   #8 (permalink)
Member: 159798
Sonork: 100.1577599
cool guys works 1000000000000000000%
Old 03-15-2013, 15:08   #9 (permalink)
Member: 1743980
Hi all, I've used the conductive tape to join back the boards, but, the iPad still doesn't recognize the modem board... There is a scheme to check if the ribbon is correctly applied?
Thx
Inviato dal mio iPad con Tapatalk HD
Old 03-16-2013, 01:16   #10 (permalink)
noobfix's Avatar
Member: 1738165
Thx
this tape is pressure sensitive, you have to press down HArd.
Old 03-19-2013, 15:58   #11 (permalink)
Member: 1785720
or get a clamp and clamp it down for awhile, worked for us.
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.27934 seconds with 11 queries
