11-16-2017, 10:41 | #31 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Quote:
Hello. After programming all the Original Data you have to Restore the Phone once again. After that you will be able to activate the phone normally. Capacity shouldn't Matter. Hope that helps. | |
The Following User Says Thank You to CDMA_RASHID For This Useful Post: |
11-25-2017, 18:48 | #33 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2750986 Status: Offline Thanks Meter: 4 | hey guys, we here in three days have solved one, "itunes 9" and two, "itunes 4013" error, and we could update without any activation errors. The model of iPhone's were two iPhone 6 and one iPhone 5s. First of all we encountered with activation problem. Interestingly we changed old NAND with used NANDs which were removed from other devices. And also brand of NANDs were different, for example we changed Skhynix with a Toshiba NAND. Surely we reprogrammed NANDs with the original S/N, Wifi and Bluetooth Address, Board Number, Color, Model, etc, etc. Briefly ios 11 didn't make any trouble for us. |
11-27-2017, 22:16 | #34 (permalink) | |
That is how it is supposed to be done. Previously before IOs 11 the Apple activation policy only needed original S/N to be reprogrammed to new Nand. Thats how everybody worked before. Nobody cared saving other information such BT/Wifi mac address and so on. Even I used to do the same. But since Apple have changed the Activation process. Now it needs all the necessary Data to be reprogrammed. To be precise the original S/N and original B/T Wifi mac address. Conclusion : Always try to Backup original data from the original Nand and reprogram it back to the New one. But if the original Nand is completely damaged and you cannot read the data then you need to buy gsx info from any web shop. And program that data to new Nand. If you guys follow these steps i hope you will have no difficulty in Activation process. Hope that helps. | |
11-28-2017, 08:39 | #35 (permalink) | |
Member: 2750986 Status: Offline Thanks Meter: 4 | Quote:
Serial Number, Model, Area, Wifi and Bluetooth Adresses, Colour, Submodel and Board Number. All of these should be original. And especially Serial Number, Wifi and Bluetooth Adresses, and Board Number are really important. | |
12-01-2017, 14:57 | #36 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2127758 Status: Offline Thanks Meter: 26 | Hi I was planning to buy a nand programmer but i've now read about this problem on ios 11... Can someone give me some information on what is possible and what is not possible at the moment? With ios 11: - Is possible to change a NAND from 16GB to 128GB? - Is possible to bypass icloud? If i got an iphone 6 where was previously changed the nand from 16GB to 64GB, there will be some problem if i will try to update from ios 10 to ios 11? Thanks in advice... |
12-02-2017, 15:40 | #37 (permalink) | |
Freak Poster Join Date: Feb 2017 Location: Russia - Izhevsk
Member: 2681265 Status: Offline Thanks Meter: 97 | Quote:
Increase the memory can be, if mac addresses and SN will be spelled out the old ones, iCloud not bypass. | |
The Following User Says Thank You to PRO-mobile For This Useful Post: |
12-05-2017, 08:19 | #40 (permalink) |
Member: 2750986 Status: Offline Thanks Meter: 4 | sabbirhossain20, did you change NAND before? If you did, find your original S/N, Bluetooth and Wifi Adresses, Board Number and write them to the NAND with a box, so you can pass the activation. But if you didn't change NAND before so want help from Apple. |
12-17-2017, 08:52 | #42 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: PHILIPPINES/BRUNEI Age: 44
Member: 343232 Status: Offline Thanks Meter: 22 | Quote:
But for ipad 64bit still no solution.. | |
12-29-2017, 17:34 | #43 (permalink) |
Insane Poster Join Date: Mar 2010
Member: 1252523 Status: Offline Sonork: 100.1617870 Thanks Meter: 8 | Hello Now i have big problem after repair error 4013 with ip box i'm stuck in activation ios 11 i have payed for the check gsx Bluetooth address but gsx have saved my fake address generated with ipbox do u know any solution or how to find for the get old and good wifi address |
12-30-2017, 09:05 | #44 (permalink) | |
01-05-2018, 20:49 | #45 (permalink) |
Registered User Join Date: Oct 2010 Location: portugal
Member: 1423542 Status: Offline Thanks Meter: 32 | MAc adress Hello, i have iphone 5s and i drill the nand flash because i have red screen, i have the mac adress and i can't activate the iphone, anyone can help me? macadress- C0F2FBA9109F wifi- C0:F2:FB:A9:10:9F bl- C0:F2:FB:A9:10:A0 thanks |
