Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides. |
| | #1 (permalink) |
| Major Poster ![]() ![]() Join Date: Nov 2009
Member: 1168213 Status: Offline Thanks: 12
| Hi. Can someone please help me ? I have a broken connector and a missing pad. Where this contact lead to because it enter into PCB? Someone can check where this going to ? It came from power switch and enter through that pad into PCB. Thank you very-very much. |
| The Following User Says Thank You to zummuz For This Useful Post: |
| | #5 (permalink) |
| Junior Member Join Date: Jan 2005 Location: Bulgaria Age: 33
Member: 103536 Status: Offline Thanks: 5
| same case Dear Zummuz and Sem_g, I see you have a good knowhow for that kind of problems... Yesterday I tried to open Ipad first generation and I made a big mistake. During opening the plug connecting logic board with on/off cable and on/off buttons I pulled to hard the plug and all wire pins disconnected from the plug. Can somebody provide me a picture with separeted cables or wireing diagram showing each cable direction in order to put them back in possition. I tried to figure out some scheme to explan better my problem. http://www.penev.org/images/ipad.jpg ![]() Million thanks in advance and thousand of appologies. Best Regards, Angel |
| | #6 (permalink) |
| There are 4 controls on that connector: 1. power switch 2. lock/mute switch 3. volume up 4. volume down In picture from sem_g from right to left: 1. power switch 2. GND 3. lock switch 4. GND 5. volume 6. volume I don't know about 5 and 6 which is up and down but you can check. Right now I don't have a opened iPad to check. Put one control to ground to select switch. |
| | #7 (permalink) |
| Thanks a lot Dear Zummuz, Thanks s lot for your fast & prompt reply. That means I have to connect both cables comming from power switch in to pins 1 and 2, counted from right to left, correct? Thanks one more time, Angel |
| | #8 (permalink) |
| Yes. But pay attention on the PCB that holds the power switch, the ground could be in contact with back-case or the screw. Don't mix the ground from main PCB with control pin from power switch PCB. Ground to ground and ctrl pin to ctrl pin. You can check with an multimeter. Otherwise you will have a full-time power switch pressed |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| DES key Driver | black | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 07-19-2012 05:32 |
| 8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-19-1999 17:41 |
