Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-04-2016, 23:53   #16 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
Originally Posted by qwertybasse View Post
the hardware method sometimes its easier than the software.
Hi can u tell me what u change i have 2 ipad 2 both same error 9
Old 02-06-2016, 12:41   #17 (permalink)
Member: 892675
Thanks Meter: 9
Why hardware? Please try 9.3 beta first.
https://www.reddit.com/r/iOSBeta/com..._for_ios_93b1/
Old 02-06-2016, 13:44   #18 (permalink)
Member: 892675
Thanks Meter: 9
Sorry beta 1 stopped. You have to go with beta 2.
Here is the link:
https://www.reddit.com/r/iOSBeta/com...ios_93_beta_2/
The Following User Says Thank You to korinakim For This Useful Post:
Old 02-10-2016, 15:45   #19 (permalink)
Member: 1939450
Thanks Meter: 165
I had the same error 9 on ipad 2. I take nand memory ic and put it on another ipad 2 with icloud and the problem was to nand memory ihad error 9 to the other ipad.
If i find nand mem. to fix them both i will post it
Can you tell me if you fixed it?
And do you maybe also know which NAND ic are compatable? iphone -> ipad to bypass icloud?
I put an ipad 3 NAND on an ipad 2, only got error 9.....
Old 02-14-2016, 05:19   #20 (permalink)
Member: 2166086
Thanks Meter: 8
ipad 4 3g error 9 100000% solved .
just need to remove R1204 component then restore with wifi firmware ..
Old 02-14-2016, 05:37   #21 (permalink)
Member: 2166086
Thanks Meter: 8
ipad 4 3g error -1 and error 50 ...100000% solved .
Old 02-23-2016, 12:09   #22 (permalink)
Member: 771798
Sonork: 100.1580.135
Thanks Meter: 27
Originally Posted by korinakim View Post
No do not do anything on hardware...
If it has very old firmware it show error 9.
solution:
ipad 2 firmware to 9.3 beta 1
and then 9.3 beta 1 to 9.2.1
working 100% thanksssss
The Following User Says Thank You to Handy-Smart.de For This Useful Post:
Old 02-26-2016, 08:19   #23 (permalink)
Member: 1216054
I'd done many of it by disconnect the battery then leave it for a night.
After, try to restore it again and its complete.
Old 02-27-2016, 13:45   #24 (permalink)
GSMsurgeon's Avatar
Member: 6524
Thanks Meter: 246
100% working !!!!!
Here is the link:
customer went to apple store they said cant do..i have used this methode...then work 100% thanks to @korinakim
Old 03-12-2016, 01:00   #25 (permalink)
Member: 388862
Thanks Meter: 107
firmware to 9.3 beta 6 is ok!!!!!!!!!!!!!!!!
iPad2,1_9.3_13E5231a_Restore.ipsw
Old 07-21-2017, 17:02   #26 (permalink)
Member: 1969931
Thanks Meter: 3
Originally Posted by bashsnk View Post
i tried it works perfectly, thanks man
what actually worked for you ?
Page generated in 0.21138 seconds with 9 queries
