01-21-2015, 17:22 | #1 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Mumbai Age: 36
Member: 821646 Status: Offline Thanks Meter: 507 | Ipad 2 : (FTL:MSG) FPART INIT So i just dissassembled it and disconnected the wifi module and cleaned its connector and reassembled it again to check wheather it worked or not.... But to my surprise ipad didnt powred on it just got stuck on Apple logo and while restore i got Error 4005 and on the ipad screen i got the following Error .... Quote:
Has anybody got any problem like this ? Or anyone has a possible solution for this issue ? | |
01-22-2015, 05:57 | #2 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2279670 Status: Offline Thanks Meter: 2 | Try reseating headphone/cameras zif, or disconnect headphone cameras etc and try booting, if it boots, the problem is likely in on of the components thats been disconnected. Another issue would be components scraped off logic board near connectors. |
The Following User Says Thank You to Pause_the_feed For This Useful Post: |
01-29-2015, 10:01 | #3 (permalink) |
Member: 821646 Status: Offline Thanks Meter: 507 | Hi..... Thanks for the reply...... I tried reconnecting every thing from front camera to charging strip and every thing possible .... I even tried swapping this faulty MOBO to another working IPad but still it had same errors on the screen ...... So this proved that all the strips and parts are fine ..... It might be something on the MotherBoard (MOBO)...... So while inspecting the MotherBoard carefully..... It proved your Second opinion Correct .... There was this resistor missing (R0703) near (J5600) Connector...... This missing resistor was my mistake, as i used a tweezer to open the connector... Now after replacing that resistor from a dead Ipad ...... The ipad now works perfect...... |
03-07-2015, 13:33 | #7 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747693 Status: Offline Thanks Meter: 5 | you need to get that signal or voltage to the component again. either by a) repairing the trace by joining a wire further down or b) look for another point on the pcb where that power/signal is and running a wire from there |
03-07-2015, 14:09 | #8 (permalink) | |
Junior Member Join Date: Feb 2014 Location: Italy
Member: 2119236 Status: Offline Thanks Meter: 3 | Quote:
So just a jumper from pins 13-12 of the connector to the capacitors R0700 R0701? (have the same identical values) | |
