iPad 2 (New Version) Power button not working after replacement Hello there, I replaced the Digitizer on a customers iPad 2 16GB NEW 2012 Version. The power button stopped working. I have replaced the power flex twice, and only the volume butons and silent switch works. The power button doesn't respond Any ideas? Thanks |
100% u broke cable se right side up there will b cable with power n volume |
check the connector on the logic board you might have damaged it upon removal. luckly this logic board is cheap Try to replace flex but don't put it in yet, just plug it in and see if it works |
hey guys sorry for reviving an old thread but im having the same issue as OP. I cut the power flex when removing shattered glass and after replacing the flex twice it still doesnt work... any ideas? :confused: thanks |
ok i repaired this before resolder connector on ipad chage ur ribbon it will work %100 |
