01-30-2015, 16:19 | #1 (permalink) |
Crazy Poster Join Date: Jun 2013
Member: 1962081 Status: Offline Thanks Meter: 6 | iPad 2 Problem Blackilight i need help about a blacklight problem on ipad 2, i checked the motherboard and i seen that a capacitor was cracked, its the C2220 on the fisrt pic (i looked the reference on a Layer iPad 2), i removed this componment and i want to replace it by an other, so i found a capacitor on the web and i bought it and try to mount it on. After that, i try to check if the blacklight is ok but it still dont work. Can someone can say me if the capacitor that i bought is ok (reference on the second pic) and if not were can i buy this cap? i Know that in a lot of case it the D8228 Blacklight IC Chip and the L2220 Blacklight Filter but i think they are ok. Thanks |
The Following User Says Thank You to tchang86 For This Useful Post: |
02-04-2015, 09:35 | #6 (permalink) |
Member: 1962081 Status: Offline Thanks Meter: 6 | sorry but im sûre that the c2220 is important for blacklight, if it not in place, the blacklight dont Work. I need to Know if the componment that i bought ( pic 2) is the same as the last pic (pic 3) |
02-04-2015, 09:50 | #7 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Romania Age: 42
Member: 81232 Status: Offline Thanks Meter: 196 | What knowledge do u have in electronics , as i see u have no clue about them . That cap is only an anti parasite capaciter , and his role is to filter . If u have an multimeter u can try to start measuring voltages , but first of all i think is better for u to start learning about components in ur ipad , and u wil understand how they all work . |
02-05-2015, 00:26 | #9 (permalink) |
Member: 81232 Status: Offline Thanks Meter: 196 | If u check schematics there must be aroud 20 v on that cap , if there are not 20 v then the prob is from inverter . U need good skills to repair that kind of problem , u can try to change diode and coil from light boost ic . |
02-09-2015, 19:20 | #11 (permalink) |
Member: 1962081 Status: Offline Thanks Meter: 6 | Hello, So i replace the diode and it dont solve my problem, i checked the filter and there is a continuity so its ok too... Can someone have an other idea? Is someone know where i can buy the C2220? I will post a pic but all is clear Regards |
02-10-2015, 18:46 | #14 (permalink) |
Member: 1962081 Status: Offline Thanks Meter: 6 | So for i Think i found the problem, the grey cap that i put on the third pic is not the good componment, i removed it and i made a jumper and the blacklight is working!!!!! So i Think its the place for L2200 is anyone can confirm??? Regards |
08-26-2015, 07:20 | #15 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1888242 Status: Offline Thanks Meter: 1 | Hi tchang86, I have the same problem that you have the schematics that I have for the ipad 2 is different that the actual ipad 2 that I have its missing the L2200 and it doesnt have the L8229 its exactly as your ipad 2 on the last picture. I have change the d8228 diode and still I have a backlight problem, what fix your problem and did you figure out which was the L2200 ? Thank you |
