Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-30-2015, 16:19   #1 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
iPad 2 Problem Blackilight
hello,
i need help about a blacklight problem on ipad 2, i checked the motherboard and i seen that a capacitor was cracked, its the C2220 on the fisrt pic (i looked the reference on a Layer iPad 2), i removed this componment and i want to replace it by an other, so i found a capacitor on the web and i bought it and try to mount it on.
After that, i try to check if the blacklight is ok but it still dont work.
Can someone can say me if the capacitor that i bought is ok (reference on the second pic) and if not were can i buy this cap?
i Know that in a lot of case it the D8228 Blacklight IC Chip and the L2220 Blacklight Filter but i think they are ok.
Thanks
The Following User Says Thank You to tchang86 For This Useful Post:
Old 01-31-2015, 10:22   #2 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
Someone can help me????
Old 02-02-2015, 02:12   #3 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Check or change D8228 and L2200 one by one.
Make sure C2200 is not shorted to ground on both sides.
Old 02-02-2015, 10:15   #4 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
Thanks for your reply, How can i test the c2220? And the componment that i bought with the référence on the 2nd pic, is its ok for replace?
Regards
Old 02-04-2015, 02:50   #5 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
c2220 don't need to replace. iPad will work without it.
Old 02-04-2015, 09:35   #6 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
sorry but im sûre that the c2220 is important for blacklight, if it not in place, the blacklight dont Work.
I need to Know if the componment that i bought ( pic 2) is the same as the last pic (pic 3)
Old 02-04-2015, 09:50   #7 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
What knowledge do u have in electronics , as i see u have no clue about them .
That cap is only an anti parasite capaciter , and his role is to filter .
If u have an multimeter u can try to start measuring voltages , but first of all i think is better for u to start learning about components in ur ipad , and u wil understand how they all work .
Old 02-04-2015, 10:41   #8 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
Ok so can u say me where i can buy this cap?
You said i can measure the voltage but of what? I cant measure voltage on cap???
Old 02-05-2015, 00:26   #9 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
If u check schematics there must be aroud 20 v on that cap , if there are not 20 v then the prob is from inverter .
U need good skills to repair that kind of problem , u can try to change diode and coil from light boost ic .
Old 02-05-2015, 04:14   #10 (permalink)
cal_guy's Avatar
Member: 1430995
Sonork: 100.1613203
Thanks Meter: 312
Old 02-09-2015, 19:20   #11 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
Hello,
So i replace the diode and it dont solve my problem, i checked the filter and there is a continuity so its ok too...
Can someone have an other idea?
Is someone know where i can buy the C2220?
I will post a pic but all is clear
Regards
Old 02-10-2015, 09:31   #12 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
This is the pic
Regards
Old 02-10-2015, 15:19   #13 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
Its an ipad2 wifi and The c8232 and the l2200 are not on motherbord, only a componment on the right of the d8228, and i dont know what is it. (3rd pic Brown componment)
Old 02-10-2015, 18:46   #14 (permalink)
Crazy Poster
Member: 1962081
Thanks Meter: 6
So for i Think i found the problem, the grey cap that i put on the third pic is not the good componment, i removed it and i made a jumper and the blacklight is working!!!!!
So i Think its the place for L2200 is anyone can confirm???
Regards
Old 08-26-2015, 07:20   #15 (permalink)
Member: 1888242
Hi tchang86, I have the same problem that you have the schematics that I have for the ipad 2 is different that the actual ipad 2 that I have its missing the L2200 and it doesnt have the L8229 its exactly as your ipad 2 on the last picture. I have change the d8228 diode and still I have a backlight problem, what fix your problem and did you figure out which was the L2200 ?
Thank you
Page generated in 0.20237 seconds with 9 queries
