05-18-2017, 08:43 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Poland Age: 35
Member: 863309 Status: Offline Sonork: 4540726 Thanks Meter: 41 | iPad 4 iTunes Error 9 iPad in DFU mode. I already cheange: USB cable USB port Battery Touch screeen Erase NAND IP BOX v2 Camera And still after few second on screen I have info about error 9. Someone have a solution or good advice how to repair ? |
06-24-2017, 12:56 | #2 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2588255 Status: Offline Thanks Meter: 29 | Hi, try with 3eTools, -> see iTunes. ipad recovery mode when you throw software, does serial no? -> Nand is not ready for the software. No problem reading. Voltage, write feet should be checked.. |
06-24-2017, 20:12 | #3 (permalink) |
Crazy Poster Join Date: Mar 2017
Member: 2697189 Status: Offline Thanks Meter: 37 | error 9 is usually unexpected drop from usb, is the battery charged enough minimum 20%? to rule that out isolate the battery and run at 4.2v 2.1amps via psu, make sure battery posts are isolated. I am fairly sure HDFU which is what you have now is not able to charge a battery, this is due to system priorities in hdfu mode, it runs the barebones systems from usb power. No serial number can be derived from a fresh nand install in itunes, thats actually why it trips hdfu. |
The Following User Says Thank You to TBC01 For This Useful Post: |
