07-29-2015, 07:55 | #16 (permalink) | |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | Quote:
The Following User Says Thank You to kaptanci For This Useful Post: |
07-29-2015, 13:23 | #17 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | yes i used 100 preheat then 350 but the thing wont budge so i think i burnt it and destroyed and lifted a few pads on it, so this one is going to scrape heap. thanks again for your help by the way i use KADA 852D hot air station |
07-29-2015, 15:58 | #18 (permalink) |
Member: 2289832 Status: Offline Thanks Meter: 48 | I not think it is burned. There r 2 pads which has no connection if u lifted those no problm u can still solder. U can also make new pads if not too much work for u. |
08-01-2015, 07:08 | #19 (permalink) |
Member: 1668980 Status: Offline Thanks Meter: 35 | Hi just and update on my progress, i finally got the nand ic off reballed put back in and still freezes, then i decided to use that nand on a icloud locked board i had and restored and it worked a treat, my nand ic was sandisk 32 and the icloud one was toshiba 32GB so it is a good option for anyone with this problem. |
08-05-2016, 22:32 | #23 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 315344 Status: Offline Thanks Meter: 5 | hello forum, I have IPAD 4 wifi 16gb with icloud lock and it was working fine. Now i have removed the NAND and now there is nothing. when i connect to the USB without NAND it says "USB device not recognized" not detecting iphone even in DFU mode. Could you please help me and suggest me what to do why it is not detecting in DFU mode. Regards |
01-17-2017, 00:42 | #24 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2659760 Status: Offline Thanks Meter: 0 | Hi kaptanci r u solved this problem??? I also have a ipad 4 with same problem. I supply 4v to it. It just consump 50ma and dosent change. So i also checked powers.. I think it seems to be ok. But i found it something wrong point. i2c0 &i2c1 pull up volt is not 1.8v. (PP1V8 is ok but PP1V8_H5? is not....) So i think maybe problem is u2 ic.... How about u?? |
07-23-2017, 13:36 | #25 (permalink) |
Member: 315344 Status: Offline Thanks Meter: 5 | Hello dear did you solve the problem with the dead. I have iPad 4 it was working and then light was dim and then all screen is white and then black. Now it does not detect, no power. Unit is unopened. i have checked voltages on L8111 ok. But there is no volt on c3009 in t he boost section. But the device should be detected in PC. Can you tell me where to check. its new board. Regards, |
07-23-2017, 23:30 | #26 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
If you never done this before, try on a spare so you learn your heat gun and air setting. Air speed increase heat, but also heats other parts around, low air speed less heat but concentrates on a narrow space with in the nuzzle opening. | |
