Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-19-2018, 01:32   #16 (permalink)
Member: 2691507
Thanks Meter: 100
Originally Posted by timvandenboo View Post
Here is solution for A1823 -> A1822
Also need to replace wifi ic and remove PCIE and unlock wifi with a PCIE flasher.
Credits to founder
What version/model of wifi ic?
Old 07-21-2018, 00:18   #17 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 19
( 339S00249 ) ..... this works perfect on GSM to convert wifi only
Old 07-21-2018, 16:45   #18 (permalink)
Member: 2691507
Thanks Meter: 100
Thanks...
On Ali Exp they are also advertising 339S00308 do you know if it works?
Old 07-21-2018, 17:56   #19 (permalink)
Member: 2266076
Sonork: Propery
Thanks Meter: 19
Thanks...
i dont have any idea about that module-->(339S00308).
only I already tested--->>(339S00249).
The Following User Says Thank You to Repaircell For This Useful Post:
Old 08-02-2018, 07:39   #20 (permalink)
Member: 2691507
Thanks Meter: 100
Hi,
have you updated any of your unlocked ipads to ios 11.4 yet?
I'm getting an icloud lock for what was before working just fine with an ip+mac that I got some 3 or 4 months a go.
Old 08-04-2018, 18:59   #21 (permalink)
Member: 2430597
Thanks Meter: 83
it works 339S00308 Wifi ic
The Following User Says Thank You to volk12 For This Useful Post:
Old 08-09-2018, 02:43   #22 (permalink)
Member: 2856755
What wifi ic does to this model? A1823 converted to wifi would be the A18322
Old 08-14-2018, 09:04   #23 (permalink)
Member: 2277735
Thanks Meter: 215
Hi,
You need to do model etc as well, activation more strict and needs all details to be correct!
Need iPad Pro 10.5 scmatics as well!
Old 08-16-2018, 13:19   #24 (permalink)
Member: 2691507
Thanks Meter: 100
One of the reasons I have not updated my ZXW dongle, last time I looked they had an ipad pro schematics that didn't match a bit.
Old 08-17-2018, 11:12   #25 (permalink)
Member: 2277735
Thanks Meter: 215
Please save to a pdf as need to fix tuch on10.5 but all filters are ok!
Old 08-18-2018, 16:31   #26 (permalink)
Member: 2691507
Thanks Meter: 100
One of the reasons I have not updated my ZXW dongle <---- Did not renew, no access any more...
BTW: some how touch don't work on any of the ipads I open before exempt an ipad pro 12.9 so if you figure out I'll be watching this post.
Old 08-20-2018, 14:37   #27 (permalink)
Member: 2277735
Thanks Meter: 215
I bought an 10.5 logicboard just to test my 2 screens.. The problem you have and all will have on pros is you have to isolate all power before removing and adding screens or you will have to test all filters as will always ****. 12.9 has loads of videos, try Iphone rehab on YouTube, is simple to fix! 10.5 all filters, resistors are reading fine, can run from trace point all the way throw so 10.5 is different point on logicboard from 12.9!
Old 08-27-2018, 09:41   #28 (permalink)
Member: 2691507
Thanks Meter: 100
Disconnecting power before detaching screen and digitizer is the first thing I learned working on iPad screen repair lol "knock on wood" I have never burn a screen filter.
Old 06-21-2019, 01:20   #29 (permalink)
Zaki Bouzidson's Avatar
Member: 2287326
Thanks Meter: 54
I guess 339S00249 is cheaper than 339S00308!!!
Old 01-09-2020, 22:59   #30 (permalink)
Member: 2804020
Sonork: 1679940
Yes guys, remove resistor, remove nand and wifi ic, but after need new serial and need to replace wifi ic with 339S00249, after everything works fine. Regards.
Page generated in 0.19053 seconds with 8 queries
