02-22-2017, 14:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2588255 Status: Offline Thanks Meter: 29 | ipad air 2 4G icloud bypass A1567 1. Jump resistor. ok -> auto dfu mode on. 4g close and wifi mode on. 2. Wifi IC change ipad air 2 wifi module (a1566 wifi ic) Wifi mac adress N/A problems. Tried 2 wifi ic, but it did not work, why? (Wifi ic -> ipad air 2 wifi models wifi ic A1566 ) There are those who do it on YouTube. It happens without changing it with jailbreak, but it forgets again in every software. ICFix.vn perfect full hd. sample. Do I have to do something with Nadn IC? thanks. Is the problem wifi ic or nadn or solder? |
The Following User Says Thank You to emrez For This Useful Post: |
03-24-2017, 09:32 | #5 (permalink) |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | You need the 339S0521 wifi ic I strongly advice you to get an grey version the black ones suck and have a high failure rate. ALSO DONT HEAT THEM UP ABOVE 280 DEGREES YOU WILL KIL THEM. Then you will have no wifi/bluetooth adress in your info. |
The Following 2 Users Say Thank You to timvandenboo For This Useful Post: |
03-25-2017, 16:54 | #7 (permalink) | |
Junior Member Join Date: Mar 2017
Member: 2698789 Status: Offline Thanks Meter: 0 | Quote:
It's the 339S0251? thanks | |
10-01-2017, 01:30 | #12 (permalink) |
No Life Poster Join Date: May 2016 Location: 574 Age: 31
Member: 2567774 Status: Offline Thanks Meter: 255 | need steps after bypass I have bypassed iPad Air 2 a1567 pretty easily. now on iOS 10.3.3 and stuck with grey wifi switch. Have been looking into sideloading .ipa's but none can accept dev settings of app without network connection. Anyone know if we can tether laptop to iPad through cable? |
