Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 02-22-2017, 14:17   #1 (permalink)
Member: 2588255
Thanks Meter: 18
ipad air 2 4G icloud bypass A1567
Hi,
1. Jump resistor. ok -> auto dfu mode on. 4g close and wifi mode on.
2. Wifi IC change ipad air 2 wifi module (a1566 wifi ic)
Wifi mac adress N/A problems.
Tried 2 wifi ic, but it did not work, why? (Wifi ic -> ipad air 2 wifi models wifi ic A1566 )
There are those who do it on YouTube. It happens without changing it with jailbreak, but it forgets again in every software.
ICFix.vn perfect full hd. sample.
Do I have to do something with Nadn IC?
thanks.
Is the problem wifi ic or nadn or solder?
The Following User Says Thank You to emrez For This Useful Post:
Old 03-07-2017, 10:47   #2 (permalink)
Moderator
Sitlay KING's Avatar
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,574
Thread moved to hardware sec,Hope you will get better help here.
Old 03-07-2017, 15:07   #3 (permalink)
Member: 378659
Thanks Meter: 2
fix wifi address in hhd this ok
Old 03-24-2017, 04:22   #4 (permalink)
Member: 2698789
Did you get it to work?
What ic have you used?
Old 03-24-2017, 10:32   #5 (permalink)
Member: 1939450
Thanks Meter: 150
You need the 339S0521 wifi ic
I strongly advice you to get an grey version the black ones suck and have a high failure rate.
ALSO DONT HEAT THEM UP ABOVE 280 DEGREES YOU WILL KIL THEM.
Then you will have no wifi/bluetooth adress in your info.
The Following 2 Users Say Thank You to timvandenboo For This Useful Post:
Old 03-24-2017, 17:02   #6 (permalink)
Member: 2698789
Then I just need to change the ic and pray that it does not fail
thank you very much
Old 03-25-2017, 17:54   #7 (permalink)
Member: 2698789
That chip does not exist,
It's the 339S0251?
thanks
Old 03-27-2017, 12:16   #8 (permalink)
Member: 1939450
Thanks Meter: 150
It's the 339S0251?
thanks
Correct sorry for the typo
Old 03-29-2017, 08:00   #9 (permalink)
Member: 2588255
Thanks Meter: 18
wifi ic 339S0251 replace work perfect (silver ic work / black not work )
Old 04-15-2017, 03:07   #10 (permalink)
Member: 2525690
Do you need to reprogram nand or just to make jumper and change ic?
Old 04-18-2017, 14:02   #11 (permalink)
Member: 2698789
I bought a black ic, is not it?
Old 10-01-2017, 02:30   #12 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 240
need steps after bypass
I have bypassed iPad Air 2 a1567 pretty easily. now on iOS 10.3.3 and stuck with grey wifi switch. Have been looking into sideloading .ipa's but none can accept dev settings of app without network connection. Anyone know if we can tether laptop to iPad through cable?
Old 10-01-2017, 07:46   #13 (permalink)
Member: 1228709
Thanks Meter: 242
Hello, you can use Bluetooth connection to get internet.
Old 10-01-2017, 22:46   #14 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 240
May you explain how sir
Sent from my SM-G928T using Tapatalk
Old 01-08-2018, 21:44   #15 (permalink)
wgr
Member: 941523
Thanks Meter: 3
as other ask , Do you need to reprogram nand or just to make jumper and change ic?
The Following User Says Thank You to wgr For This Useful Post:
Page generated in 0.36336 seconds with 7 queries
