03-28-2017, 20:07 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2700678 Status: Offline Thanks Meter: 0 | Ipad air 2 bypass icloud I have an ipad air 2 model A1567 (cellular), I made a jumper on marked place and then restored with firmware ios 10.2.1. The iPad works, the wifi does not go. How should I proceed to run the wifi? Thanks in advance |
03-28-2017, 21:37 | #2 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2634857 Status: Offline Thanks Meter: 25 | Hi there, I have an iPad air A1475 removed R1506 and its recognised as WiFi only but the restore A1474 firmware won't flash can you give info on your restore process. Mines stuck in dfu mode no image and doesn't pull any amps 0.09amp Sent from my X98 Plus 3G using Tapatalk |
03-28-2017, 22:36 | #3 (permalink) | |
Crazy Poster Join Date: Mar 2017
Member: 2697189 Status: Offline Thanks Meter: 37 | Quote:
yours is air1 double check it was R1506, have never had a problem. Was it flashing correctly before removing? I use a pin vice with a sewing needle to flick off resistor, I dont like to put heat near cpu... | |
03-28-2017, 23:09 | #4 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | Covered the CPU with kapton and surrounding area and heated 4mm nozzle and flicked off with needle . can't post picture but came off clean. Just wondering if apple have sorted this via the firmware. Has anyone completed in last few days with success. Its read as an air in 3utools and gets to sending ram disk then hangs and fails. ITunes at 20% the same Sent from my X98 Plus 3G using Tapatalk |
03-29-2017, 09:21 | #11 (permalink) |
Freak Poster Join Date: May 2015
Member: 2393089 Status: Offline Thanks Meter: 29 | Yes ipad air 2 GSM and WiFi have different WiFi driver. To install you need Jailbreak and then replace driver from WiFi version. Connect to internet using Bluetooth tethering from another deviance (MacBook, Android...) At the moment there are no Jailbreak for 10.2.1 but be ready or replace WiFi ic from air2 WiFi model and problem solved permanently. sent from gsmsverige |
03-29-2017, 18:48 | #12 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | [01:05:21.0830] ProcessOverlappedIoRequest: failed, error 997, usbd status 00000000 That's from the error log from iTunes. Does that mean usb cable issue. Its not genuine. Sent from my X98 Plus 3G using Tapatalk |
03-29-2017, 21:54 | #13 (permalink) |
Member: 2634857 Status: Offline Thanks Meter: 25 | All sorted it was the charging cable tried 3 cables all had different resistance on the data lines so bought brand new cable and voila 10 mins and flashed. After 4 days . will post photos later. Sent from my X98 Plus 3G using Tapatalk |
03-29-2017, 23:53 | #14 (permalink) | |
Member: 2700678 Status: Offline Thanks Meter: 0 | Quote:
ic wifi which I have to put on ipad air 2 ? the model | |
