08-22-2017, 08:46 | #49 (permalink) |
Insane Poster Join Date: Jun 2016
Member: 2582013 Status: Offline Thanks Meter: 2 | Hello guys i have also 3x ipad air 2 lte and i have already this WIFI ic from aliexpress .... because of the IC is very thick ... what is the temp/time that u work on that because its not as easy as the other ICs .... i have a friend that works around 350c for 3 4 minutes and then its again hard to remove it because of the F**** black resin under ... give me tips of the TEMP/TIME before i start guys , thank you in advance , i like this thread , i am following |
08-23-2017, 06:53 | #50 (permalink) | |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | Quote:
4 minutes is to long. shield everything around the IC Pre-heat the board for about 30 seconds 180% is fine, then increase heat to 350c (melting point of lead free solder) You need a very fine spatula or you can use a pin like the ones that come in clothing (very fine) Push the spatula or pin under one side only, but keep heat even and do that one by one until you raise the IC, you'll need at least 2-3 pins If using spatula work just 1 mm on the edge free of components (no pads there) once in move it side to side (1 mm in) that helps separate on that side, then on one edge push spatula all the way in, take it out, go to the other side and do the same, at this point your IC might just pop up and if not then slide the spatula inserted all the way in from side to side (SLOW) Something you need to pay attention is to push Horizontal (NOT IN AN ANGLE) All that needs to be done under 2 minutes. Remember is not the solder holding the IC is the Glue so you don't need to keep putting more heat on the board or you'll damage other components. Last edited by cisco2017; 08-23-2017 at 07:02. | |
10-21-2018, 19:42 | #51 (permalink) |
Member: 2691507 Status: Offline Thanks Meter: 100 | WOW memories .... Came across my old post when working on the iPad Air 2, I finally figured how to fix the elusive "waiting for ipad" itunes error pad-air-2-error-4014-after-change-nand-serial |
10-21-2018, 20:08 | #52 (permalink) | |
Freak Poster Join Date: May 2016 Location: Colombia
Member: 2575005 Status: Offline Thanks Meter: 41 | How you fix that bro Quote:
10-22-2018, 07:51 | #53 (permalink) |
Freak Poster Join Date: Sep 2015 Location: UAE
Member: 2461303 Status: Offline Thanks Meter: 65 | error 4014 in ipad air 2 coming by SDRAM , before sombody overheat flash ic for 4013 -i first change flashic then the 4014 error comes,next i reball SDRAM it works .flashing fully done |
The Following User Says Thank You to EAKANATH For This Useful Post: |
11-08-2018, 20:20 | #56 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1675922 Status: Offline Thanks Meter: 61 | have two air2 boards that after removing nand are detected in dfu -> disconnect -> dfu again and that's it... my guess was that the ram is causing the issue, but on another board with same symtoms after remove ram the balls seemed ok, without bridges... any idea? thx! |
11-11-2018, 07:38 | #57 (permalink) | |
Try a restore with 3utools and pay attention to the error on the animated graphic, why, read my link on how I fixed "waiting for ipad" Description on what you did helps to diagnose basic problems like over heating surrounding IC is short: Need Work history steps Temperature shield used or not Line test (voltage) Did you check Nand pads on the board & Nand (some times they become lose if you use to much heat) Error codes Post as much information so that our viewers can help you and others can learn. How I fixed waiting for ipad Last edited by cisco2017; 11-11-2018 at 07:45. | |
11-11-2018, 18:22 | #58 (permalink) | |
Member: 1675922 Status: Offline Thanks Meter: 61 | Quote:
Without nand, on itunes i get error 4014 and on 3utools not able to go from dfu to recovery Didn't tried to re-attach a nand... i desoldered and solder back all nearby ICs (except ram ofc): U3000, U2000, U2180, U7503 On 3utools it stuck on 11% enter recovery mode: unable to go from dfu to recovery PSU shows 50mA when disconnected from USB, and 0 when connected All voltatges seem normal and steady. Thx! Last edited by mcmihai003; 11-11-2018 at 18:31. | |
11-11-2018, 19:15 | #59 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | Quote:
11-11-2018, 22:53 | #60 (permalink) | |
i know about error 4014 due to improper nand programming. but also the board should be able to enter in recovery without nand - this is my case.. thx again! | |
