06-18-2019, 16:30 | #1 (permalink) |
Registered User Join Date: Dec 2012 Location: canada
Member: 1848477 Status: Offline Thanks Meter: 3 | iPad Air Nand Programming issues I also tried with naviplus and got to the same point. Confirmed it's the nand issue not the ram, by restoring in itools without nand. On 3 different units, same issue so it's not my method, i think. Hello, having issues removing icloud on an ipad air a1475 Here is exactly what i am doing : Note : Without nand, the ipads give UNABLE TO RESTORE DEVICE(-1) = NOT RAM (NAND PROBLEM) Ram is very protected, im not causing any ram issue. 1 - Remove resistor near cpu 2 - Remove nand from board 3 - format nand 4 - Selecting ipad air with * model 5 - Put info in 6 - writeboot 7 - writeinfo 8 - resolder nand and try to restore, stuck at 19% in itools and error 9 in itunes. Anyone can help on this one ? Stuck for hours, ive removed and put back nand about 20 times. |
The Following User Says Thank You to cheebster For This Useful Post: |
06-20-2019, 20:22 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Congo Kinshasa
Member: 2148606 Status: Offline Sonork: Bobobokota Thanks Meter: 496 | The issue is in PCIe nand before format you must save backup or change nand with old write boot and write information What programmer you use Envoyé de mon iPhone en utilisant Tapatalk |
06-21-2019, 09:19 | #3 (permalink) | |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Quote:
The Following User Says Thank You to orx For This Useful Post: |
