01-07-2013, 13:05 | #4 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: tbilisi, georgia Age: 33
Member: 1679251 Status: Offline Thanks Meter: 385 | Quote:
same details has ipad 2 http://forum.gsmhosting.com/vbb/9036346-post16.html also ipad 3 near power management ic but wait for noobfix's answer | |
01-07-2013, 17:24 | #5 (permalink) | |
Banned Join Date: Mar 2012
Member: 1738165 Status: Offline Thanks Meter: 206 | Quote:
yeap same 4r7 coil, ipad mini is really the same as ipad 2 ipad 1 is different is more like a macbook air it use coil 100 instead of 4r7 and require more parts. I would change the other parts first tho, IMO coil is usually the last thing goes wrong, unless you have water damage like in iphone, then the coil become the weak spot as well. | |
01-07-2013, 19:35 | #6 (permalink) |
Insane Poster Join Date: Jan 2008 Location: kuwait
Member: 678448 Status: Offline Thanks Meter: 25 | that ipad mini lcd is before backlight its working wen i check Some new lcd backlight stopped sir i changed ic and coil take From i pad 2 but same problem .. sir |
01-08-2013, 18:50 | #11 (permalink) | |
http://forum.gsmhosting.com/vbb/9036346-post16.html | |
01-09-2013, 00:21 | #12 (permalink) | |
no it have to be the same or close value backlight filter. other wise you are risking of unstable light or burning out of the chip or it will not work at all. | |
02-18-2013, 21:40 | #13 (permalink) |
Freak Poster Join Date: May 2012 Location: dubai Age: 38
Member: 1766383 Status: Offline Sonork: [email protected] Thanks Meter: 4 | |
04-08-2013, 09:02 | #14 (permalink) |
Junior Member Join Date: May 2008
Member: 768425 Status: Offline Thanks Meter: 12 | i pad minilight solution 100 % http://forum.gsmhosting.com/vbb/newa...manageattach&p= masterphone..bah |
05-29-2013, 17:33 | #15 (permalink) |
Junior Member Join Date: May 2013
Member: 1949742 Status: Offline Thanks Meter: 1 | I don't understand how a backlight coil or IC can be damaged just by unplugging it from the motherboard? |
The Following User Says Thank You to AllCrackedUp For This Useful Post: |
