02-19-2015, 03:01 | #1 (permalink) |
Insane Poster Join Date: Aug 2014 Location: Australia
Member: 2249587 Status: Offline Thanks Meter: 11 | iPad mini battery percentage only 1% or 100% At first it showed 28% battery, but then turned off and needed to be charged, after charging it showed 100% while I tried draining the battery all day. I did that twice leaving it overnight to charge. I then put it in DFU mode and updated to IOS 8.1.3 and now it is showing 1%, I put it on charge but it is still saying 1%. The lightening symbol shows when it charges, just the percentage doesn't change. Any tips? |
02-19-2015, 05:31 | #3 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Angeles City
Member: 697643 Status: Offline Thanks Meter: 68 | try disconnect and then connect it again the battery.... then try to recharge it again.... |
The Following User Says Thank You to howell For This Useful Post: |
02-24-2015, 00:03 | #6 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2279670 Status: Offline Thanks Meter: 2 | Yup, I'd bet money the components to the left of the battery connector on logic board are chipped away! |
The Following User Says Thank You to Pause_the_feed For This Useful Post: |
02-24-2015, 05:13 | #8 (permalink) |
Member: 2249587 Status: Offline Thanks Meter: 11 | Ouch! What a mess, many thanks for pointing that one out. My advice, be extremely careful when removing the battery connector, even a plastic tool can dislodge those parts! |
02-24-2015, 07:55 | #9 (permalink) |
Member: 2249587 Status: Offline Thanks Meter: 11 | Job done. I tried soldering that fusible link (that is loose in that picture) to no avail, its just too tiny for my eyes. Ended up just soldering a thin piece of wire across it instead. Turned it on, and instantly it showed 87%, and is increasing as it should when charging. I left the capacitor off as it was missing, its even smaller, hopefully it doesn't matter! |
