09-16-2013, 09:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: damak,jhapa,nepal
Member: 1705433 Status: Offline Sonork: kali Thanks Meter: 45 | ipad mini no power |
The Following User Says Thank You to kali_fuchi For This Useful Post: |
11-10-2013, 19:14 | #5 (permalink) |
Member: 1705433 Status: Offline Sonork: kali Thanks Meter: 45 | yes its u2 ic problem, its solved by reball u2, even iphone 5 also have same problem because of u2 ic, its available on all new model apple product. |
01-31-2015, 00:46 | #9 (permalink) |
Junior Member Join Date: Apr 2006
Member: 253290 Status: Offline Thanks Meter: 0 | [QUOTE=richard26;9751161]try tihs solution, hope it helps if still has the same problem, try this one... change power management ic or PM ic ________________________________ I have the same problem: my iPad Mini is dead but there is no heat in any IC…. any idea? |
01-31-2015, 00:59 | #10 (permalink) |
Junior Member Join Date: Apr 2008
Member: 747693 Status: Offline Thanks Meter: 5 | I have the same problem, although my charging port isn't working at all, have replaced with new part still no luck. So assuming U2 ic is to blame, then maybe power ic if all else fails. Guys have any recommendations on hot air settings for iPad U2 ic? Thanks, |
