02-01-2018, 18:48 | #1 (permalink) |
Freak Poster Join Date: Oct 2016
Member: 2634857 Status: Offline Thanks Meter: 25 | IPad mini no power not charging Had caps missing near battery FPC so replaced (not the filter) Then had 0 v coming out from TriStar : with battery and TriStar attached. PP3V0_S2R =0V PP1V8_S2R= 0V PPVBUS_PROT = 4.95V ON Q8104 there is vbat voltage of 3.26v which is batt voltage On Q8104 there is VCC main voltage of 3.86v (low I think) On Q8104 = Act diode =3.3v (so pmic is not dead ) Not charging and no LCD image lead me to believe pmic fault. Changed TriStar and have the following : PP3V0_S2R =2.99V PP1V8_S2R= 1.79v PPVBUS_PROT = 4.87V TriStar outputs seem ok. Now! Are you able to help shed some light on the diode mode readout for VCC main as I'm getting 176mv which seems low and as seen in the video there seems to be a short near VCC main pads area under pmic or is this just heat build up upon startup on the line? This happens when charger is plugged in. The battery also drains when attached but fine when left off so it seems there is a short draining it. I know the pmic needs changing but would like to know a bit more abt the fault as haven't had much work with iPads. It seems a lot of these shorts could be avoided if the design of ground pad placements were thought out more and not surrounding live pads... Any feedback most welcomed..http://cloud.tapatalk.com/s/5a7352bf...ic%20short.mp4 Sent from my X98 Plus 3G using Tapatalk |
