Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 08-23-2016, 10:41   #1 (permalink)
Crazy Poster
Member: 189861
Thanks Meter: 14
Exclamation iphone 6 Plus Short in Q1403
hello i have iphone 6 Plus Short in Q1403 ..
im fix the problem in iphone 6 remove c1552 But .. not work in 6 plus
can help me ??
thx you
Old 08-23-2016, 15:32   #2 (permalink)
Crazy Poster
Member: 189861
Thanks Meter: 14
plz Help me.............
Old 08-23-2016, 21:14   #3 (permalink)
Member: 1796117
Thanks Meter: 16
I assume you think Q1403 is short because it is getting hot? Q1403 will always get hot on short on VCC_Main. Remove Q1403, add voltage to line after Q1403 and find real issue causing the short.
The Following User Says Thank You to cqljohn For This Useful Post:
Old 08-24-2016, 00:32   #4 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
Its short Vcc main ..remove q1403 and try inject voltage on red mark to find short ..after u find short then jump q14013 good luck bro
Sent from my iPhone using Tapatalk
The Following 4 Users Say Thank You to irzhan01 For This Useful Post:
Old 08-24-2016, 15:23   #5 (permalink)
Crazy Poster
Member: 189861
Thanks Meter: 14
thx you i will try .. and replay
Old 08-29-2016, 07:41   #6 (permalink)
Member: 2301208
Thanks Meter: 2
i have 1 this problem did u manage to fix this
Old 09-03-2016, 10:35   #7 (permalink)
Member: 2204585
my iphone full short with q1403 . i trying remove c1552 and c1597 it not slove on my iphone 6 . any body for any solusion ?
Old 09-04-2016, 04:05   #8 (permalink)
Member: 2598526
Thanks Meter: 52
Q1403 connects vbatt to vcc_main. If q1403 getting hot it's because there is a short on vcc_main
Old 09-04-2016, 07:46   #9 (permalink)
SAEIDSANGAN's Avatar
Member: 1691551
Sonork: 100.1622582
Thanks Meter: 53
check voltage in and out pm ic
Old 09-04-2016, 14:32   #10 (permalink)
Member: 2453408
Thanks Meter: 63
pmu doesn't work when vcc_main is short because there is a huge voltage drop...
Old 09-05-2016, 00:32   #11 (permalink)
Member: 1929960
Thanks Meter: 27
You don't need to remove Q1403 as long as vbatt is not shorted.
Just jump power to VCC_main and find the hottest cap without heating up Q1403
The Following User Says Thank You to warboat For This Useful Post:
Old 05-03-2017, 19:51   #12 (permalink)
Member: 985157
Thanks Meter: 3
remove C1585 works like charm )
Old 05-12-2017, 10:31   #13 (permalink)
rrvius's Avatar
Member: 1821491
Sonork: Never give up
Thanks Meter: 35
Wear is that C1585 location i have 6 with same problem replaced U2 got short in q1403 c1417 short removed q1403 and 1401 still short also cap shors near Pmic caps and C5202_rf short how to find short
Sent from my SM-J500F using Tapatalk
Old 03-12-2018, 06:01   #14 (permalink)
Member: 1211915
Sonork: 345634564
Thanks Meter: 93
Genius person, i found short.
Old 03-14-2018, 06:58   #15 (permalink)
Member: 1178779
Thanks Meter: 18
can anyone show me the solution for i have the same problem still i cannot fix pls send a good picture so that i can see it clearly thanks in advance...
The Following User Says Thank You to jigs69 For This Useful Post:
Page generated in 0.24042 seconds with 8 queries
