09-11-2016, 21:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | ipad Nand Ic compatible can someone confirm if nand swap is compatible with iphone 5 we can use in ipad mini 1 gen I have been able to format and change serial on iphone 5 nand then restore in ipad mini, but having problem with itunes restore (waiting for ipad ). I have many cases of this happening same with iphone 5S to ipad air or do i need to order same model nand ic? has anyone tried this yet? Thank you |
11-22-2016, 11:49 | #2 (permalink) |
Freak Poster Join Date: May 2015
Member: 2393089 Status: Offline Thanks Meter: 29 | iPad 2 iPhone 4 revision with small NAND chip iPad 3 (if 2 NAND flash chips than SN in U1400 chip?) iPhone 4s, iPhone 4 (?) iPad 4 iPhone 5 iPad mini 1 gen iPhone5, iPhone 4? (revision with small NAND chip?) iPad Air 1 gen iPhone 5s or iPhone 6 iPad mini 2 gen iPhone 5s iPad Air 2 gen iPhone 6 iPad mini 3 gen iPad Pro 1 gen iPhone 6s iPad mini 4 gen iPad Pro 8.9″ (Air 3) iPhone 6 or iPhone 6s |
The Following 12 Users Say Thank You to Gsmsverige For This Useful Post: |
04-13-2017, 08:36 | #4 (permalink) | |
Freak Poster Join Date: May 2013 Location: Netherlands
Member: 1939450 Status: Offline Thanks Meter: 165 | Quote:
ipad Pro has a PCIE NAND not a 64 Bit nand so this is not correct. Then only iphone 6s should be compatible. But people keep in mind that you can get problems with you gyroscope because of different driver installations in the NAND. Just use a flasher (ipbox, wl tool etc) to remove icloud properly. | |
The Following User Says Thank You to timvandenboo For This Useful Post: |
07-28-2017, 00:17 | #6 (permalink) |
Junior Member Join Date: Dec 2009 Location: Netherlands, Gelderland
Member: 1190472 Status: Offline Thanks Meter: 9 | Ipad air 2 works also with iphone 5s nand. Only screen orientation in landscape mode is upside down. |
The Following 3 Users Say Thank You to rb0wag For This Useful Post: |
09-17-2017, 10:16 | #8 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Aegean Sea
Member: 1520712 Status: Offline Thanks Meter: 19 | where can we find a good serial nomber for ipad etc for naviplus? is any site with clear serial or sometrhing becouse in luck type serial maybe must solder and desolder all the time any help i preciate thanks in advance |
06-07-2018, 09:07 | #13 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277735 Status: Offline Thanks Meter: 215 | Ipads convert to wifi only and change nand or serial, and macs with nand programer... Iphone 7,8,x and ipad pros have new nands so pins are different, you need a different nand programer that has to correct pin out for the new nands! Navi plus 3000s for 32 bit and 64 bit nands New (6s?)7,8,x pros need an PCIE nand programer PS: anyone have clean Ipad 4 (seiral and macs) details as need to activate facetime and imessinger! can pay no problem!! |
06-20-2018, 22:01 | #15 (permalink) | |
Junior Member Join Date: Apr 2018
Member: 2826478 Status: Offline Thanks Meter: 0 | Quote:
I used iphone6 on ipad air 1st gen and it wouldnt activate as it was waiting for me to insert a sim card? | |
