03-30-2015, 22:17 | #4 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2369935 Status: Offline Thanks Meter: 0 | Hi, I Have exactly same ipad 4 first error 4005 after reflow error 4014 after reballing same error 4014, now i replaced NAND for another one, exactly same form IPAD 4 ipad stuck in during restore time on "waiting on ipad" checked with 3 laptops. Did you do something with this NAND from another mainboard or just take out form MB fit and restore?? Any ideas? Thanks for any solutions |
10-13-2015, 10:05 | #5 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2157654 Status: Offline Thanks Meter: 1 | Hello friend, did you solve a problem with ipad 4? I have the same issues,it's in DFU mode, getting itunes error 4005, black screen, waiting for ipad....What to do? Please help if have solution!!! |
12-26-2016, 13:42 | #11 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2112917 Status: Offline Thanks Meter: 0 | can anybody confirm this is the right fix? I'm about to order the IC to fix my iPad4 3G 32Gb that is having this same issue, tried to restore it on DFU like million times and it always bloody fails. thanks! |
12-26-2016, 21:12 | #12 (permalink) |
Freak Poster Join Date: Mar 2013 Location: Greece Age: 35
Member: 1903358 Status: Offline Thanks Meter: 146 | This solution is obviously only for the WiFi iPads. It should have been clarified. To change Nand on Cellular iPad you need to programming it first. Also iPhones and iPads uses NAND memory, not EMMC. |
09-15-2018, 09:50 | #14 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2691507 Status: Offline Thanks Meter: 100 | I don't get it ??? How did the PMU got damaged from replacing NAND? Or perhaps can you explain what type of work did you do on your iPad 4 before "waiting for ipad" because the PMU sits all the way on the other side of the board and even if it got damaged due to a short, you didn't mention anything about fixing a short first. |
The Following User Says Thank You to cisco2017 For This Useful Post: |
